Question about ASUS X551MAV-RCLN06 Black 15.6" Notebook 2.16 GHz Intel Celeron N2830, 4 GB DDR3, 500 GB HDD, Intel HD Graphics, DVDARW, Windows 8.1, LED Backlight
Cursor arrow will not move - ASUS X551MAV-RCLN06 Black 15.6" Notebook 2.16 GHz Intel Celeron N2830, 4 GB DDR3, 500 GB HDD, Intel HD Graphics, DVDARW, Windows 8.1, LED Backlight
    New Friend:
  • 155 Answers
It may just be a driver issue, try to use a plug in mouse or just key navigate to hardware manager and uninstall mouse pad driver, then reboot and it will self reinstall, then try to update driver through the hardware manager, other wise, go into bios on start up, search for mouse pad enable/disable make sure pad is enabled.
Posted on Mar 12, 2015
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,363 Answers
Assuming that you already powered off/on to reset it, then most likely the PAd itself is bad, you can buy a seperate new pad, but unless you know how to remove a BUNCH of screws and get to it then I would take it to a local shop or have a tech that advertises for 30-45 $ to do it.
6ya staff
SOURCE:
Cursor not moving when using keyboard arrows
they won't move the cursor.
Only the selection.
Nov 22, 2013 | Microsoft Excel for PC
Fx-82ES How to use the replay button?
After you execute a command (=) and have the result displayed, you can press the Left Arrow of the Replay button to move the cursor to the end of the last command line.Use Left arrow/Right arrow to move cursor along the line and modify it (change a value, operation sign, etc.) After you make the changes press the = sign to execute the modified command.
Jan 30, 2012 | Casio Office Equipment & Supplies
When i press the Y function of my calculator instead of appearig PLOT 1 , PLOT 2 and 3 it says graph 1 grapgh 2 and graph 3 how can i put it back on plot?
1. Press up or down arrow to move the cursor to the line of the setting that you want to change.
2. Press left or right arrow to move the cursor to the setting you want.
3. Press enter.
Jan 24, 2011 | Texas Instruments TI-84 Plus Silver...
Get it out of scientific mode!
  1. Press [MODE] .
  2. On the top line that says Normal Sci Eng use left arrow to move highlight from SCI to NORMAL an press [ENTER] to validate the setting.
  3. After that, you must set the number of decimal digits: use down arrow to move cursor to second line. FLOAT 0 1 2 3 4 5 6 7 8 9
  4. Use left or right arrow to highlight the number of digits you want. If you want 2 decimal digits, move cursor or 2 and press [ENTER]
  5. Press [2nd][QUIT] to exist the [MODE] screen.
Feb 10, 2010 | Texas Instruments TI-83 Plus Calculator
JVC XV-M555 DVD player has the parental control set somehow. Need to know how to disable the parental control on this DVD player
Found the manual for the player buried in a box from moving. Procedure is
1) With no DVD in player
2) Press enter while holding down shift to display parental lock menu
3) If you dont remember the password enter 8888 to access the options
4) Use cursor to move arrow to country code option
5) Use right cursor to select country code, then down cursor to move country code to US
6) Use left cursor and down cursor and right cursor to move to set level
7) Use down cursor to toggle through level options. (None removes all blocks)
8) If setting a level toggle down to password and set new 4 digit password.
Jan 01, 2010 | JVC XV-M555 Multi-disc DVD Player
When in a spreadsheet, the arrow keys do not move cursor
first try to see the cursor is not within the cell blinking cause sometimes when the cursor is within the cell it traps the controls and will not able to function on your desire output. so try to observed it again.
Jun 16, 2009 | Microsoft Excel for PC
Swintec 2000 Margin
You should reset the margins where you would like them. To do this, go the the file screen and press MARGIN. Press <--- to change the left margin, or ---> to change the right margin, or the up arrow to change the top margin, or the down arrow to change the bottom margin.
Do one at a time. When you choose one (i.e. <---), the message "LEFT MARGIN SETTING" appears on the screen and the cursor moves to the left margin column automatically. Move the cursor to the desired location by using the arrow keys. As you move the cursor, the corresponding margin mark moves along with it. The press "DO" to set the new margin.
Hope this helps.
Jay @ www.granadahillsbusinessmachines.com
Aug 26, 2008 | Swintec 7040 Typewriter
Up arrow key sticks
This fix also works for the LX 710 Cordless! Yay! Thank you.
Nov 14, 2007 | Logitech Cordless Desktop MX3200 Laser...
How can I change the Resolution?
Olympus has its own way of showing the resolution settings. It is OK once you get used to it. Turn the Camera On. (On the back you will see an OK button surrounded by 4 arrows.) Press the OK button to bring up the menu. Press the left arrow button That should bring up a choice of: TIFF, SHQ, HQ, SQ1, SQ2 Use the up/down arrow buttons to move the cursor to SQ1 Then press the right arrow button That should bring up a choice of settings. Use the up/down buttons to select a setting. I suggest you select 2048x1536 (which is 3 megapixels) Then press the OK button. ................ You should think about getting a memory card with a greater capacity.
Sep 06, 2005 | Olympus Camedia C-60 Zoom Digital Camera
ASUS X551MAV-RCLN06 Black 15.6" Notebook 2.16 GHz Intel Celeron N2830, 4 GB DDR3, 500 GB HDD, Intel HD Graphics, DVDARW, Windows 8.1, LED Backlight Logo
54 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
