k
kendehoul renaud Posted on Mar 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Taskalfa 250ci error code C1400 - Office Equipment & Supplies
CheckitRight
Level 3:
Renaissance:
An user who is expert in 3 categories / brands.
  • Master 1,363 Answers
  • Posted on Mar 12, 2015
CheckitRight
Master
Level 3:
Renaissance:
Answers
1363
Questions
Helped
646739
Points
2795
2answers
How solve error 9540 on Kyocera 3051?
I would check the connection to the main board as a backup error code can be caused by intermittant connectors.
I'm using Taskalfa Kyocera 250ci, there are enough toners inside the catridge. And, it's still complaining about toner saying add toner. What can be the cause of it?
1 or more of the developers is leaking. because the machine adds toner based on a ratio of developer to toner when the developer level is not right machine tries to compensate by adding toner it will always say add toner until the developer unit is changed
1helpful
How do i fix error code C7103
you need to replace the magenta developer unit
How to fix error code c 9540 for kyocera taskalfa 250
should not try to copy money!!!! you need to call kyocera they will help you or something
2answers
Error code taskalfa 500ci , c3300
C3300, AGC Error. something in the copy lamp or optical section
I have a problem Taskalfa 250ci eror code c0640 I think at Hdd problem. But I don't know how to hdd format
Maintenance
item No.
U021
Memory initializing
Description
Initializes all settings, except those pertinent to the type of machine, namely each counter, service call history
and mode setting. Also initializes backup RAM according to region specification selected in maintenance item
U252 Setting the destination.
Refer to *1 of the maintenance mode item list about the item initialized.
Purpose
To return the machine settings to their factory default.
Method
1. Press the start key.
2. Press [EXECUTE] on the touch panel.
3. Press the start key. All data other than that for adjustments due to variations between machines is initial-
ized based on the destination setting.
4. Turn the main power switch off and on.
For errors occurred, turn main power switch off then on, and execute initialization.
Error codes
U024
HDD formatting
Description
Initializes the hard disk.
In addition, the following settings are also initialized by initializing the hard disk.
System menu (user login administration, job accounting, address book, one-touch keys and document box
etc.), shortcuts and panel programs
Purpose
To initialize the hard disk when replacing the hard disk after shipping.
Method
3. Press the start key to initialize the hard disk.
Description
Codes Description
01 Configuration initialization error
02 Counter initialization error
20 Engine initialization error
40 Scanner initialization error
2JZ/2JX/2JV/2H7-5
1-3-23
2answers
k24674
ADMIN Andrew
ADMIN Andrew
