1993 Geo Storm Logo
Christopher Kaylor Posted on Mar 12, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Does a distributor from a 1993 geo storm gsi 1.8 fit a 1993 geo storm base?
I have a geo storm base and i need a distributor, only used ones around me are for geo storm gsi both 1993
c20cdn
Level 2:
Sergeant:
  • Expert 167 Answers
  • Posted on Mar 12, 2015
c20cdn
Expert
Level 2:
Sergeant:
Answers
167
Questions
0
Helped
50489
Points
544
Most probably not, the GSi has a different head. Base has a 12 valve, GSi has a 16V. Check for part numbers. Do you need just the cap or the entire distributor?
I NEED A VACUUM HOSE DIAGRAM FOR A 93 GEO STORM GSI DOHC ENGINE. 1.6 AND 1.8L.
mitchells DIY (google it....)
log in and read?
and be lots more than only vacuum on that ISUZU Impulse (clone)
for SURE.
vacuum can be different in Canada than USA and in California.
(smog laws dictate all vacuum devices, most)
no country stated, in USA?, then use mitchells.
EGR and evap are diffr.
Does 1992 geo storm gsi have timing belt or timing chain
great question. but confuses <STORM (an ISUZU) with METRO, Swift.
ill assume the STORM is correct and the 1.8l too.
that engine is a ISUZU Real engine,
and is called the
4XF1 ,see facts below.
now the cam answer.
in the uSA this car is the GSI model with 1.8L
see last link for your answer. below. GM official page.
you can also see your cam in the 2nd link below.
the engine is INTERFERENCE. so if the belt snaps, it bends valves
just like all HONDAs do.\
http://www.agcoauto.com/content/List_Of_Interference_Engines
wiki facts.
The larger 1.8 L 4XF1 DOHC replaced the 4XE1 in North America and produces 140 hp (104 kW) and 125 ft/lb (169 Nm) of torque. This engine was used in the 1992-1993 Geo Storm GSi, in the 1992 Isuzu Stylus RS, and in the Asuna Sunfire. In Japan it was installed in the Isuzu Piazza, where it had 150 PS (110 kW).
http://www.gmpartsdepartment.com/parts/1992/Geo/Storm/2Plus2%20GSi?siteid=214533&vehicleid=73792&diagram=F200040&diagramCallOut=13
rockauto shows the belt. see it?
http://www.rockauto.com/catalog/x,carcode,1177017,parttype,5759,a,www.google.com%2BSearch%2Bfor%2B1992%2BISUZU%2BSTYLUS%2B1.8L%2BL4%2BEngine%2BCrankshaft%2BSeal
How to program ECM in 93 geo storm
very good question.
you cant. (not easy)
what that means is , on geos.
is you buy a used, or rebuilt ECU with the same part number as your car, and it will be programmed right.
the equipment of the dealer to do this is now all gone and relics.
The Tech1 scanner and FLASHers are rare as hens teeth today.
and even more air, the binary files to do the flash.
(find a match)
the ecu,must match ,year, transmission, calif. or fed. and engine options.
there may be some storm pros that know how to Rom swap it (A > B)
the ROM, but is very complex topic. based on the type and year of base ECU you are running.
see all the bad news here.
http://wiki.answers.com/Q/What_is_the_problem_with_a_Geo_Storm_when_it_tries_to_stall_when_idling_at_a_red_light_andor_when_the_same_car_wants_to_stall_when_you_try_to_back_it_up_in_the_parking_lot
2answers
What is the engine size of a '92 geo storm
The Geo Storm is was equipped with a 1.6L 4 cylinder engine,
the GSI Geo Storm had a 1.8L 4 cylinder engine.
I have a !993 Geo Storm GSI 1.8 and I'm only
Got to be in the firing, coil pack probably.
2answers
5helpful
How to change fuel filter on a 91 geo storm gsi
the fuel filter is direclty below the brake booster mounted on the left side fender when your facing the car from front but be careful as to not twist and break the metal hoses on the fittings on the filter
1993 Geo Storm |Transmission
There is no way they would leave you stuck with the engine!! However, the odds are that it should fit. First check the flywheel or flex plate. [Not sure if its a auto or manual.] If they bolt on, your are into installing the engine! Good Luck with it! Frankster016
Top Geo Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Geo Expert? Answer questions, earn points and help others
