If that is a 3.5 HP Briggs Engine you're referring to then I believe you want a (Champion) CJ8 plug. Cross-references to the following mfg's: Autolite 255, Bosch WS8E, Champion CJ8, 843, NGK BM6A, JOHN DEERE AM54450, LESCO 010769 . Hope this helps James
Chances are you wont get a manual, just lube it up.tires probably 12 to 15 lbs .the belt is mecanicly tensioned so there is no adjustment. Check the idler pully tensoner and ingage lever for proper travel and tention
If your mower does not have "OHV", overhead valves. You can use a Champion j19lm spark plug. If you discover you do have overhead valves; A Champion RC12YC, will work.
