see this causes and fix it. God bless you
Air filter:If the vacuum cleaner won't pick up dirt and has no suction the air
filter might be clogged. Remove the filter and either clean or replace
it as needed.
Exhaust Filter
If the vacuum cleaner won't pick up and has
no suction the exhaust filter might be clogged. Remove and clean the
filter, replace it if its torn or damaged.
Vacuum Hose
no suction the vacuum hose might be clogged. Remove the hose from the
vacuum cleaner, stretch it out straight, shine a bright flashlight in
one end and try to see light through it. If no light can be seen, use
something to run through the hose and free up the obstruction.
Vacuum Bag
no suction the vacuum bag might be full. Clean or replace the bag as
recommended by the manufacturer.
Dust Cup AssemblyIf the vacuum cleaner won't pick up and has no suction the dust cup
assembly might not be installed tightly, or it might be cracked or
broken. The dust cup must seal tightly in order to produce the right
amount of suction. If it is cracked or broken, replace it. Most glues
and adhesives will not successfully seal the crack.
Blower Wheel
If the vacuum cleaner won't pick up and there
is no suction, the blower wheel might be jammed or broken. Check the
blower wheel to be certain it turns freely. If it doesn't, check to see
if there is anything rubbing against it. If not, but it's hard to turn,
the motor is most likely the problem.
