If you are talking about Rainbow loom, or a similar rubber band loom, all the printed instructions are hard to follow. Try youtube. The kids are better at explaining than the adults. This girl is quite easy to follow http://youtu.be/ukv83Cvq3jk
I would call fisher price technical support at 1888-892-6123. You should be able to request an instruction manual for your item. I found this number on www.fisherprice.com. Thank you and have a good day! I hope this helps.
check wiring loom for brakes ,First test horn by connecting directly to battery .You need only one wire .Attach one terminal of the horn to -- negative post and with a lengh of wire attached to the other terminal of horn flask across the positive pole .if the horn is ok it will sound off .If this is all ok then you need to trace the horn wiring for breakages or the horn button itself may be corroded and not making a good .contact .
take the hook provided and loop each loop over the next until you get to the end and then tie that one off for a hanging loop. My kids and grandkids have these looms, hope this helps.
Sandy
