I-INC UniK Trio AXS 3G with Wifi 7.85" Touchscreen Quad Core Tablet Mach Speed 1.2 GHZ 16GB 2014 Release T-Mobile 3G Slim Folio Case [Bonus Stylus] - Hot Pink Logo
James Boyd Posted on Mar 11, 2015
How do I get skype on this device - I-INC UniK Trio AXS 3G with Wifi 7.85" Touchscreen Quad Core Tablet Mach Speed 1.2 GHZ 16GB 2014 Release T-Mobile 3G Slim Folio Case [Bonus Stylus] - Hot Pink
Any solution why I can't received any calls in XPOD phablet.
How to fix Samsung Galaxy S4 that can't receive text ...
thedroidguy.com/.../how-to-fix-samsung-galaxy-s4-that-cant-receive-tex...
Aug 14, 2015 - A phone that can't get signal can't send/receive text messages and make/receive phone calls. In this step, try to see if the phone is getting a ...Missing: xpod ‎phablet
Getting started with Skype (Android tablets) - Skype Support
https://support.skype.com/.../getting-started-with-skype-android-ta...
SkypeWith Skype for Android tablet, you can make free voice calls and video calls, ... With this option enabled, you don't have to tap any buttons to answer incoming calls. ... a replacement for your telephone and can't be used for emergency calling.
how to make skype video call of xpod tablet pc - howdroid.net
howdroid.net/q/how-to-make-skype-video-call-of-xpod-tablet-pc.html
How to make Skype video calls on Android using Fring ... With either, we can make andreceive Skype calls, but we cannot see the other person. ... but yet can't figure out how to make a video call, I can't see this option anywhere, any idea?
Can I make phone calls using my notebook?
Try the Magic Jack App or Skype or even Viber
I just brought a he Sharper Image M18A" Tablet. Can anyone tell me if you can use Skype - as in see the other person. I know it's to do with the cameras on the tablet but when I brought this I wa
If you don't see the person you are chatting with on Skype, the issue is probably on their hardware. You do need to "Enable Video Call" from the Skype app's Menu after initiating a video call. If you aren't seen on the other party's side of the call, then it's your device settings that must be adjusted.
Does your tablet have a front-facing camera and Android version 2.3 or better? (The M18A is listed as having Android 4.0) If so, then you should be able to video chat with the Skype app. When you use the rear-facing camera, obviously there are issues with the other party seeing you.
If you have a front-facing camera, make sure that this is the default camera while the Skype app is closed. Open the default camera app and tap the icon to toggle the front camera interface (if needed). Then switch to video mode. Return to the home screen and open the Skype app. Login and start a video call. Then press Menu (in the app) and "Enable Video Call".
If this doesn't work, you may need the IP Webcam app. This is available at the Play Store. After setting the default camera, set the resolution and the frame capture rate, among other settings. Next, follow the directions for using Skype for a video call.
I hope this helps.
2helpful
2answers
HOWI CAN I INSTALL SKYPE IN MY iPad 2(16GB)?
you will need a itunes account and then go to the app store. search for skype and install. it will prompt you to create a skype account if you do not already have one.
Is there a way to skype or tango
Not with this device - it can't load those programs since it doesn't run Windows.
6helpful
Skype for archos
you can get skype for Android here http://www.freeware4android.net/archos-28-internet-tablet-4gb-8gb-device-1663/skype-android-download-17736.html
Toshiba Satellite 1905
First, try pluging in an exteral mic to check the mic itself is not broke. Next Go to the device manager to check for driver problems (control panel, system, Hardware look for yellow ?'s) Check control panel, Sounds and Audio, audio, sound recording, volume. There are just too many ways to mess with the sound settings, and they often seem to just mute themselves!
Good luck
Top I-INC Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an I-INC Tablet and eReader Expert? Answer questions, earn points and help others
