2006 Chevrolet Trailblazer Logo
A
Anonymous Posted on Mar 11, 2015
2006 chevy trailblazer is not charging battery. battery and alt are new
Once in a while it might come up to 13volts but never higher. i will have a fully charged battery and the volts slowly drop to where it quits. battery and alt new
Jeff Armer
Level 3:
  • Chevrolet Master 15,575 Answers
  • Posted on Mar 11, 2015
Jeff Armer
Chevrolet Master
Level 3:
Answers
15575
Questions
Helped
7099113
Points
73899
Volts slowly drop to where what quits ,The vehicle stops running ? Is the charge indicator light lit on the instrument cluster /? are any lights lit on the instrument cluster ? The instrument panel cluster (IPC) illuminates the charge indicator and the BATTERY NOT CHARGING message is displayed in the message center when the following occurs:
The engine control module (ECM)/powertrain control module (PCM) detects that the generator output is less than 11 volts or greater than 16 volts. The IPC receives a serial data message from the ECM/PCM requesting illumination.
The IPC determines that the system voltage is less than 11 volts or greater than 16 volts. The IPC receives a serial data message from the body control module (BCM) indicating the system voltage.
The IPC performs the displays test at the start of each ignition cycle. The indicator illuminates for approximately 3 seconds.
The ignition is on, with the engine off
  • Jeff Armer Mar 11, 2015
    You need to check for Battery + voltage at the heavier wire on the Alternator,The computer turns the alternator onthrough the smaller red wire in the two wire connector on the alternator.the heavier red wire has a fuesable link ,could be blown if no power there
Jump start trailblazer will run that day but next day it is dead there is a short some where
2006 Trailblazer won't start - Discussion on Topix
www.topix.com > Chevrolet TrailBlazer
Sep 6, 2012 - My 2006 Trailblazer will not start, bought a new battery, still will notstart, not even with a jump. ... i get a jump i drive it and charged the battery it seemed fine but then i went ... Then, next morning, when I turn key, all lights come on and radio... back a day and 360$ well that pos still will crank but will not start. 02 trailblazer a/c problem
Jul 21, 2011
2003 trailblazer key is stuck in ignition
Dec 21, 2009
2003 Chevy Trailblazer will not start
Jul 21, 2009
2002 trailblazers won't start
Aug 24, 2007
More results from www.topix.com
Alternator intermittent charging
an alternator charges between 13volts and 15 volts usually. it is regulated by the battery's need internally. this internal regulation is accomplished by the diode trio and or the voltage regulator within the alternator. be sure that the heavy lead from the alternator to the battery is clean and tight and that the battery terminals are clean and tight.
1helpful
Alt gauge reads low
This sounds like the alt is not charging, but a eak battery will also cause this condition, what you can do is have the charging system tested. if you have a volt meter you can connect it to the battery with engine running and acc off you should have 13.5-15 volts,this is a good alternator, then turn on all acc and check it, it may have a low reading but should atleast go to 13volts and then when you rev it up it should go to 13.5 - 14.7. if the readings are low replace alternator.
2answers
Charging problem?
clean grounds on moter and body and headlight wires
Not charging
First tell me why you don't think it's charging.
Because of the voltage reading you are getting at the battery terminals? The range you want is between 13.6v to 14.2v. The higher the voltage the lower the amps. and true the other way, the lower the voltage the higher the amps. If you get a reading of 13.6v or lower, the alt is nearing or at max output. An alt can only run at maximum for around fifteen minutes and it will start slinging solder from overheating. It's a good indication the battery is either totally dead or junk. Charging above 14.2 the alternater is running wide open and is only putting out high volts which will cause the battery to boil , in turn destroying it. This is a bad alternater. All alternaters have integrated voltage regulater with the exception of ver few of the earlier ones. You cannot test an alternater by removing a battery cable to see if the engine keeps running without taking great risk of damaging the alt, regulator. So tell me why you feel it isn't charging. Remember an alt is not made to charge dead batteries. Their sole function is to maintain the battery charge. Without a battery, the alt won't last 10 seconds.
Hope to hear from you and good luck.
4helpful
2answers
1998 k1500 5.7l 105a alternator. replaced
Now change the sulfated batery for a new one.
Vitally
3answers
Same problem motor shutting off when turning the AC at a low idle
I don't tjink your a/c is directly killing the engine. The electrical load it demands may be the issue. Hve your battery checked and your alternater outout. The alt. is supposed to ofset the loads imposed on the battery so as not to ppermit the battery to drop below what is needed to satisfy other accessories which are on orrunning. The charging voltage output of the alt is 13.6 - 14.2v @ 13,6v the alt is charging near its capacity. and 14.2 it is backing off. The lower the voltage the higher the amps. Constantly running @ or below 13.6 will shorten the lufe of the alt due to hear builup damage. Have your battery load tested w/engine off. Then ck the alternater output engine running @ 800 rpms. Alternaters, unlike the old generators, charge from the minute it starts turning, where a generatoter has to have speed to generate anything. Watch what the alternator does when you turn the a/c on and off. or simply watch the battery readinsgs when you turn each accessory on. like the headlights... Good Luck
Changed belt on 02 trailblazer now it won't start
Belt turns alternator, alternator charges battery.(no belt, no charging) Charge battery with a charger. Though it may start with a jump, the alt is designed to maintain the state of charge in the battery, not to fully charge it . Therefore jumping puts too much demand on alt and can damage it. or will shorten battery life considerably.
2helpful
2answers
1988 chevy suburban charging system problem alternator wont charge new alternator new ignition switch good battery good belt removed old alarm system removed and replaced fusible links no shorts in system...
First check alt At The Back of Alt Big Red Wire Were hooks to Post (stud) Do you have voltage ?? How Much??
What Voltage do you have at same Place with Engine Running ??
Now At wires Were they plug into Alt ,Top. Wires in White Plastic Clip, Do You Have Powe With Key On ?? How Much Voltage??
Jump across the 2 in the clip (with Engine Running)ONLY TEMPORARY!! Do You Have Voltage at Battery ?? How Much??
If Over 13volts With Clip On (Jumped) You Need A Internal Voltage Regulator ..
Is Batt Light On on Dash ??? Theres A Lot Of Testing You Can Do !!! And I will Need More Infomation to Keep Going ... These are just some Possible Problems No Way In Depth ...
Could Be a Number of things Or May be Just as Simple As a Blown Fuse, Dirty Batt Cables ETC etc etc I Hope It Puts You On The Right track !!!!!!!!!!
Top Chevrolet Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
john h
Are you a Chevrolet Expert? Answer questions, earn points and help others
