When you sew the machine must be set at the correct settings. If your machine won't straight stitch, turn it off at the power point and then turn it back on. Most machines reset to the default straight stitch setting. Secondly when you sew the presser foot must be down. This engages the "feed dogs" or the triangular looking "teeth" below the presser foot. As you sew, the feed dogs grab the two layers of fabric pulling them through, the thread above (spool) and the thread below (bobbin) meet to form the stitch. Finally, maybe fiddling around with dials and settings you may have dropped, or disengaged the feed dogs. Check with your manual on how to re-engage the feed dogs. Hope this helps and happy sewing. Remember, when all else fails..... read the manual.
Have you accidentally dropped the feed dogs? If the feed dogs are not in the up position, they will fail to pull the fabric under the presser foot.
If all else fails, you might have to have the feed dogs adjusted for height. At their maximum they should protrude .09 mm or .035 inch.
This model should have an adjusting screw with a locking nut. This information won't be in the manual but I have adjusted several brother machines for this same problem with success.
