Computers & Internet Logo
A
Anonymous Posted on Mar 11, 2015
I have an Asus Eee pc R101D netbook, Cant get it to fully boot up, operating system is Windows 7 Starter, I have no Re-installation Disc, Also cant get my external Disc drive to work from the USB slot, I need some advice please, the hard Drive has been out, and replaced with another one, don't know if that's anything to do with it. Anyone with any ideas, it just says after so far booting up re-install installation Disc which I don't have, is there any other way of getting it to boot up properly, cant even get to promt command, Help someone
Bonded Repair
Level 3:
Master:
  • Master 407 Answers
  • Posted on Mar 11, 2015
Bonded Repair
Master
Level 3:
Master:
Answers
407
Questions
0
Helped
91391
Points
1065
Your operating system is located on the hard drive if you still have the old one and it works put it back in make a back up copy on cd remove and reinstall new on and load operating system to new hard drive.
tip
Retrieve Password on ASUS Eee Pad Tablet
Looking For a Password Recovery Program to Access Your Locked ASUS Netbook? Apple's iPad 2 maybe the hottest thing on the hip-happenin' trendy tablet block, but Asus isn't that behind with its own version, currently dubbed the Eee Pad. Till April 2011, this computer has occupied a considerable market share. In this article, we will learn how to <a href="http://www.windowspasswordsrecovery.com/retrieve-asus-password.htm">retrieve ASUS EPad Password</a>. <br /> <a href="http://www.windowspasswordsrecovery.com/images/knowledge/retrieve-asus-password/asus-eee-pad-tablet-password-big.jpg"><img src="asus-eee-pad-tablet-password.jpg" /></a> What is ASUS Eee PC? Asus Eee PC is a subnotebook/netbook computer line from ASUSTeK Computer Incorporated, and a part of the Asus Eee product family. At the time of its introduction in late 2007, it was noted for its combination of a light weight, Linux operating system, solid-state drive and relatively low cost. Newer models have added the option of Windows operating system and traditional hard disk drives.<br /> The first Eee PC was a milestone in the personal computer business, launching the netbook category of small, low cost laptops. According to Asus, the name Eee derives from "the three Es," an abbreviation of its advertising slogan for the device: "Easy to learn, Easy to work, Easy to play".<br /> Some of ASUS's hot products <b>Eee Pad</b>: Eee Slate EP121, Eee Pad Transformer TF101<br /> <b>Eee PC</b>: Eee PC T91, Eee PC 1000HD<br /> <b>EeeBox PC</b>: EeeBox PC B201, EeeBox PC EB1502<br /> How to Regain Password on ASUS Eee Pad Tablet? There are 2 passwords in an EPad, a bios password, an Operation System password. We will separately discuss the 2 cases.<br /> Bios Password Bios password is setting on the bios config, we can press Del button during loading the PC to enter bios config menu, then remove the bios password. Sometimes, you don't know the bios password, look this guide: "<a href="http://www.blog.windowspasswordsrecovery.com/top-3-methods-to-crack-bios-password/">Top 3 methods to crack bios password!</a>".<br /> <b>Tips</b>: As we know, EPad uses touch screen. We could connect it with a USB keyboard to press Del button. <br /> Operation System Password We can install many OS on an ASUS tablet, for example: Linux, Unix, MAC OS, Windows. Here we discuss only windows. <b>1.</b> Download <a href="http://www.windowspasswordsrecovery.com/downloads/Windows_Password_Recovery_Tool_Ent_Trial.exe"><b>Windows Password Recovery Tool</b></a> (free trial).<br /> <b>2.</b> Install and run it.<br /> <b>3.</b> Create a password reset disk. A CD/DVD disk, or a USB Flash Disk, depend on the locked ASUS PC's support.<br /> <b>4.</b> Boot the locked ASUS computer from the password reset disk. <br /> Note: You may need to config bios setting to set it boot from the password reset disk. The 2 articles can help you.<br /> a. <a href="http://www.windowspasswordsrecovery.com/getting_started/bios.htm">Boot from the CD/DVD-ROM</a><br /> b. <a href="http://www.windowspasswordsrecovery.com/getting_started/bios_usb.htm">Boot from the USB Flash Drive</a><br /> <b>5.</b> On the password recovery Windows, select the user account that you forget its logon password, click "reset" button.<br /> <b>6.</b> Confirm you action, then that user's password will be removed.<br /> <b>7.</b> Disconnect the password reset disk, and reboot your ASUS computer. You will access Windows OS without password ( blank password ).<br /> Finally Get away from the troubles of forgetting ASUS PC Password, no matter it is bios/cmos password or Windows password. <br /> Tips: <b>1.</b> The Windows Password Recovery Tool supports all versions of Windows OS, including Windows 7, Vista, XP, 2000, 2003, 2008. It is popular way of regain your password, even you don't have a password reset disk. <br /> <b>2.</b> Keep in mind that this tool can be only used on your own computer, never try to use it to crack PC password without permission. Otherwise, you will get into trouble by law.<br /> <b>3.</b> You can <b><a href="http://www.windowspasswordsrecovery.com/create-windows-7-password-reset-disk.htm">create a ASUS Eee Pad Password Reset disk</a></b> before you forget password. <br />
on May 23, 2011 • Computers & Internet
I cant switch on my netbook n it require me to reboot but i cant even do anything.
I can tell you the solution but first tell me.
Which Operating system you have Installed on your Netbook?
1helpful
Asus eee pc 1015x
Hello
The answer is YES. You can load Win-7 from an external DVD player, after making it as first boot device. You must have get DVD as first boot devce and the internal hard disc to second boot device. Click out all boot devices to none, by entering into the bios window. You can get the bios settings, by press and hold the "Delete" key of your computer, as it first try to load. OK.
I have a asus Eee pc notebook,when i turn it on the message REBOOT AND SELECT PROPER BOOT DEVICE appears how do i do that?
check if there is any fashdrive or memory card plugged in. if it shows that message it might mean your pc cant detect a bootable harddrive. was it working before? was it dropped or bumped maybe the harddrive got loose. at the bootup screen do you see your harddrive? if your pc can still detect your harddrive try installing a fresh copy or your operating system. hope this helps.
2helpful
2answers
My son was watching a movie through a usb memory stick on his eee pc r101d. he pulled the stick out while the movie was playing, now netbook will not restart. I tried system repair, files loaded half-way...
Sounds like a critical system file was damaged. If the system repair fails (also safe mode), as a lastg resort you can always re-install Windows over the existing installation. Don't format the disc and you will find all of his old files in C:\windows.old
How can i get Asus Eee PC back to factory settings?
Hi. Actually when you restore your system to its factory settings it will restore everything on your computer including the original operating system, but if you're saying that you have installed windows 7 on it then try going to ASUS driver support website, just type in their the model of your machine and it will ouput every software and drivers available for laptop and also different versions of operating system, So just choose the correct OS version for your laptop. Hope this Helps
How would i connect my laptop to my daughters netbook? is there anyway i can do this and then boot from the dvd-rom in my laptop to perform a fresh install on the netbook?? my laptop is a acer aspire 5920...
You should put the installation cd directly in the netbook. Start the netbook with the cd in the dvd drive and when the message appears "Press any key to boot from cd" press enter. Then you must follow the onscreen instructions to reinstall Windows (the procedure differs for each operating system).
Regards,
nicolasiac
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
