Using the remote for the TV, enter the menu and find the picture settings.
Adjust the brightness and contrast controls until you are happy with the picture quality. Product Support
There is a inverter next to the screen under the plastics either below the screen or next to it. This sounds like a bad transformer witch is located on the inverter board. They can be ordered on line or through most laptop stores. They are not hard to change but a common problem. make sure you know what you are doing before you attemp this. Thanks
this is a very common problem... there is a lot of literature out there... thankfully your hard drive and memory aren't shot... its a glitch... here is the link to the work around http://msinfluentials.com/blogs/jesper/archive/2008/05/08/does-your-amd-based-computer-boot-after-installing-xp-sp3.aspx
Sounds like you've entered the "service mode" where you're seeing the chroma (color) signal only.
What type of connectors are the F and S? RCA? F?
This set is no longer made which makes it hard to research. By any chance, is there a small switch on the back that says "normal - service"?
