Question about Canon DR-9080C Path-Through Scanner
Canon DR-9080c scanner not lifting error no page found in feeder
I have a Canon DR-9080c scanner that sounds like it is working, but the lifger will not lift up with paper on it. It then says no page found in feeder.
Thanks.
  • 490 Answers
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Posted on Jul 10, 2009
    New Friend:
Sometimes the sensor does not recognize pages in the feeder if there are only a small number of pages.
Try placing some blanks under the pages to be scanned.
N.Day, Australia
Posted on Apr 22, 2010
6ya staff
SOURCE:
Paper will not feed. the lift tray does work. 1.5 to 2 inches of the top of the paper feeds before it stops. when i used count only still get the same problem with
A01 is pickup error. Clean the paper sensor in the paper lifting tray and try. Clean the rubber rollers also.
S. Mohan, Chennai, India
Nov 17, 2011 | Canon DR-9080C Path-Through Scanner
Dr-9080c tray lifts up and down
IT could be a problem with the paper sensor. Please clean the sensor in the paper tray, it looks like a 'black dot' .
Nov 07, 2011 | Canon DR-9080C Path-Through Scanner
Canon scanner-the document lifting table is not lifting, it makes a noise trys lifting then stops, then a "no page was found in feeder" message appears on my computer.
At the bottom of the tray there is a sensor for checking "Home Position". When you power on the system initialises and the tray goes to the home position. Please check this sensor if it is dislocated or a piece of paper is blocking this optical sensor. Normally these sensors don't fail. Also clean the 'black dot' just under the rollers. There is a paper sensor under this and dust can prevent sensing the same. Even after this if you have noise, there could be hardware problem.
Sep 24, 2011 | Canon DR-9080C Path-Through Scanner
Scanner is not taking the pages and it is showing error message 4401
Please explain the problem more clearly.
Switch on the scanner, load some papers and try 'page count'. If it works, then there is no problem with tray lifting or paper movement. If this is not working, try 'Qumatool' and give a command to lift the paper tray. If it lifts, then the problem is with a sensor under the paper lifting tray. (It may not be in HP - Home position). If the tray is not lifting, then you may have problem with motor. S. Mohan, Chennai, India
Aug 18, 2010 | Canon DR-9080C Path-Through Scanner
Paper tray at front of scanner will not lift. Scanner has been reset multiple times and computer rebooted as well. Error msg= unknown error canon DR-6080/7880/9080C driver versioin 1.3.10502.17001 (-4523)
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
Jun 30, 2010 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C paper tray lift broken
Michael, U can buy 9080C service manual at tradebit.com 9080C has no belt for lifting the tray. It has arm and a few gears. Ensure that the plastic gears are not deformed. Good Luck. Which version of Capture perfect do you use?
S. Mohan
Jan 30, 2009 | Canon DR-9080C Path-Through Scanner
Canon Dr-9080C scanner
to check the page count install the driver and setup the scanner as a "scanner device" on your computer. Once you have done that , go to the "control panel" than "scanners and printers". Right-click on the device that says "Cannon DR-9080C" and select "properties". The device information will appear, than select the "counter" tab on the information box; the scan count will be listed.
Apr 14, 2008 | Canon DR-9080C Path-Through Scanner
IDoc scanner Canon DR-9080C has a P00 error when not paper jam found?
There are sensors in the paper path. Just blow air to ensure that there is no shreds of paper is blocking the sensor.
S. Mohan, Chennai
Mar 13, 2008 | Canon DR-9080C Path-Through Scanner
No page was found in scanner when one was there
Lift up the black frame around the large soft grey pick rollers on the upper part of the paperfeed until it locks into place. Power off scanner and back on and the trya will lift and the paper will feed.
Oct 22, 2007 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C Path-Through Scanner Logo
1,970 people viewed this question
old marine
old marine
Ekse
Tareq Bin Mostaq...
Tareq Bin Mostaq...
