Electric Strider Midi 4 Wheel Mobility Scooter - Midnight Blue Logo
A
Andy Lawrence Posted on Mar 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have an error code of 7 Flashes = drive lever not central, but it is.
I have an error code of 7 Flashes, Should I dismantle & clean it or just replace the pot? It was working fine at Xmas. I drained the batteries and recharged them at xmas. BTW scooter has been out side for approx. 2-3 years with very little use only drove it around the garden in summer. I have sprayed all terminals with an electrical cleaner but all terminals were clean.
  • Andy Lawrence
    Andy Lawrence Mar 11, 2015
    Quick fix so you can still use it. (But you lose reverse) Remove plastic dash unit & tiller section follow the wires from the trigger and remove the white plug. undo the two bolts holding the trigger in place and remove. Using a multi meter Measure the resistance (Kohms) between the Green & Red terminal then the Green & Black terminals the reading should be around 2.5 (IF IT IS VERY LOW ON BOTH READINGS THERES NO QUICK FIX) like 1 or even 0.5 (more likely the red as this is forward motion) then goto maplins or ebay and buy resistors 1000 ohms or 500 ohms in order to bring the reading close to 2.5 / eg (My reading was 0.5 so i used two 1000 ohms resistors soldered inline. Cut the red and black wires (approx middle) and solder the resistor/s on the red wire coming from the trigger to the black wire coming from the white plug. solder the other black and red wires together & insulate joins with tape or heatshrink. Now your scooter will only go forward by using the REVERSE LEVER the scooter will not go back wards if you press the forward lever it will bring up the 7 flashes error if you need to go backwards turn ignition off and lift the freewheel lever. Job Done (should take 2 hours work)
Rob Hill
Level 3:
  • Electric Master 1,480 Answers
  • Posted on Jul 13, 2015
Rob Hill
Electric Master
Level 3:
Answers
1480
Questions
0
Helped
517302
Points
3838
Hi, the lever maybe but is the actual throttle pot stem ? look a the screw slot located a the end of the pot stem ? bet you it's slightly to the left or right ...
Regards
Rob
www.gewizrepairs.co.uk
2helpful
My Kymco mobility scooter is flashing 7 times .i see a answer is the drive lever is not engaged ,what is the drive lever
The drive lever on a Kymco mobility scooter is the lever that engages the motor and allows the scooter to move forward or backward. It is usually located on the handlebars of the scooter and can be controlled by the user. If the drive lever is not engaged properly, the scooter may not function correctly and could result in the flashing 7 times error code. You should consult your user manual or a certified Kymco dealer for more information on how to engage the drive lever correctly.
Clean light flashes and dishwasher will not work
when the clean light flashes its displaying a fault code based on the number of times it flashes...if it flashes 7 times then pauses then flashes 7 times again its displaying error code#7 if 4 times then pause its code#4 ect.
This tip i wrote will tell ya how to reset the board since sometimes its just electrical anomilie..reset the board and if it again flashes let me know how many times in a row it flashes and i will determine which error code it is , heres that tip to reset the control board http://www1.fixya.com/support/r10357661-get_whirlpool_dishwasher_start_when
GENE
2helpful
The panel is stuck on pots/pans for cleaning and wont let me run the dishwasher. the pots/pans light keeps flashing
To reset the dishwasher push in this order the,
HIGH TEMP WASH- HEATED DRY- HIGH TEMP WASH- HEATED DRY - CANCEL/OFF
the control will be reset...but more importantly how many times in a row does the light flash..it will indicate what error code its displaying??
example if it flashes 4 times then a pause then flashes 4 times again its displaying the error code#4
7 flashes then pause then 7 flashes its displaying the error code#7 ect ect
GENE
Red light on on my Buffalo HD
Red ERROR LED The way the unit gives diagnostic codes is by long and short flashes of the specific light. The number of long flashes give the first of two numbers and the number of short flashes give the second. For instance, one long flash and three short flashes would indicate an error of 13 -
E 00
(No light, beep only) - MPU error E 01 DRAM data line error E 02 DRAM address line error E 03 RTC chip error E 04 Flash rom error E 10 UPS power loss E 11 fan error (RPM too low or not functional) E 12 cooling error (unable to remove heat by the fan) E 15 disk error E 16 unable to locate internal HDD E 17 Unable to communicate with the RTC chip E 21 unable to communicate with the Phy chip E 22 mount error. The original Buffalo firmware has the following error messages based on the number of flashes:
3 Partition problem with hard drive. Reformat the hard drive. 4 Fan problem. 5 ROM problem. 6 Hard Drive can not be recognized. 7 Problem with motherboard (RAM, LAN, or Hard Drive controller). Exerted from http://buffalo.nas-central.org/wiki/Information/LSProLED
I hope this has been helpful, unfortunately without more information I cannot help any further.
Stops washing mid cycle flashes f11
Here is what the manufacture says about this error code followed by my comments.
Communication between the Central Control Unit (CCU) and the
Motor Control Unit (MCU) cannot be sent correctly.
What to do:
1. Unplug washer or disconnect power.
2. Check wire harness connections to the MCU, the motor, and
Central Control Unit (CCU).
3. Check the drive system for any worn or failed components.
4. Plug in washer or reconnect power.
5. Verify CCU operation by running a Diagnostic test or any
cycle.
6. Check the MCU by looking for operations of the drive motor.
7. Check the drive motor for powered rotations.
8. Check that the serial harness at the MCU is not mounted
upside down. The wires should be to the left when facing the
MCU connectors.
Phil's comments ---------->
This error usually indicates a failure of the circuit board that controls the motor. It is a repair I would suggest leaving to a professional as it can be tricky to diagnose the problem
2answers
My is not working & shows an error code B200.
FLASHING ORANGE LIGHT ERROR MESSAGES
Try counting the number of orange flashes.
* two flashes means you’re out of paper or the paper is not feeding correctly.
* three flashes means there is a paper Jam or the output tray is closed.
* four flashes means the ink tank is empty
* five flashes means the print head is not installed correctly or not installed or is defective (before buying a new print head always try the cleaning instructions at the end of this post first.)
* six flashes means the inner cover is open or not closed properly.
* seven flashes means you counted wrong.....
* eight flashes means the waste ink absorber is almost full or full.
* nine flashes mean that a digital camera or video that is connected is not compatible with the printer. If a specific amount of time lapses without getting a response from the digital camera or video camcorder this will happen.
* ten flashes means it can not print to both sides of the page
* eleven flashes means the automatic print head alignment failed. (this can be caused by low ink levels, ink tanks not being installed correctly, the print heads being clogged. It can also be caused by the paper output slot being exposed to a strong light source (Press the resume /cancel button and move the printer to a darker location and try to align the print head again.
* check to make sure the lock lever is correctly positioned (down)
If the above does not work, align the print head manually by opening the printer properties dialog box and clicking the maintenance tab and then select the print heal alignment button on the left side, second row down.
2helpful
Armstrong upflow,unit works intermittent problem,call for heat nothing happens,error code of 5 blinks then 6 blinks. i have no manuel, and the panels dont have the codes on them. anyone have access to the...
Armstrong
FAILURE CODES
LED Status Fault Description
Off
No Power to the System Control
Steady Flash (11 or more flashes with no pause)
Normal Operation (Standby or call for heat)
2 Flashes
Pressure Switch Closed When It Should Be Open
3 Flashes
Pressure Switch Stuck Open 30 Seconds or Longer After Call for Heat (System in 5-minute delay mode before next call for heat). On/off switch in "off" position during a call for heat will generate this code.
4 Flashes
Open Limit Switch or Limit Switch Circuit
5 Flashes
Flame Sense Signal Sensed Out of Proper Sequence
6 Flashes - pause - 1 Flash (see Note 1)*
Soft Lockout Type 1 (Failure to light within 4 trials for ignition)
6 Flashes - pause - 2 Flashes (see Notes 1 & 2)*
Soft Lockout Type 2 (Flame sense lost during run)
6 Flashes - pause - 3 Flashes (see Notes 1 & 2)*
Soft Lockout Type 3 (Pressure switch opened during run)
6 Flashes - pause - 4 Flashes (see Notes 1 & 2)*
Soft Lockout Type 4 (Limit or limit circuit opened during run)
6 Flashes - pause - 5 Flashes (see Note 1)*
Soft Lockout Type 5 (Flame has gone away after Error Code 5)
6 Flashes - pause - 7 Flashes (see Note 1)*
Soft Lockout Type 7 (Self-check failure)
10 Flashes* - SV9520H8034 only
Line Input Voltage Polarity Reversed
1helpful
Washer wont agitate and then flashes F 25
If you remove three screws along the bottom front the bottom panel comes off.
On the inside, on the right wall, is a plastic bag with a paper labeled "FOR SERVICE TECHNICIAN ONLY".
This has a section titled "FAILURE/ERROR DISPLAY CODES" with all the error codes along with an explanation and recommended procedure. For F25, this is:
DRIVE MOTOR TACHOMETER ERROR
If the control is unable to properly detect motor speed, the machine shuts down.
If a failure occurs during high-speed spin, the door unlocks after 3 Minutes.
Possible Causes/Procedure
1. Verify the shipping system including shipping bolts, spacers and the power cord are removed.
2. Unplug washer or disconnect power.
3. Check drive motor tachometer resistance. It should be approx. 115 ohms.
4. Check wire harness connections between the drive motor and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU).
5. Plug in washer or reconnect power.
I got this working for many on this site :)
thank u
rate me!!
2helpful
2answers
Fault code F25
Thanks
Fame !
Top Electric Health & Beauty Experts
Rob Hill
Rob Hill
SmartAviator
SmartAviator
jws1013
Are you an Electric Health and Beauty Expert? Answer questions, earn points and help others
