GPS 38 unable to access date and time in system setup. presently shows 1 jan 05
Hi John921,
Here is the step by step procedure to set date and time of your Garmin GPS 38......
It will definitely work......
Set Local Date and Time
1) Verify the date and local time (this should be
the date and time according to the local date and
time of country/area you are in). Because the
time shows is Universal Time (UTC), you will
need to enter a time offset to display the correct
local time for your area.
2) Move the field highlight to the OFFSET field
and press Enter
3) With the arrows (←→), go to the figure which
represents the hours then with the up & down
arrows (↑↓), select the time offset for your
longitude and press .
4) Move the field highlight to the HOURS field
and change to 24 if that is not already the case.
This will definitely work......
Please rate this solution............
Thanks......
