The cooling fan was dried out and boken and all parts got oveheated. the wire and computer board was melted
SOURCE: Samsung model RS2530BBP is not
Hi, Refrigerator or Freezer not Cooling or Getting Cold
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
heatman101
SOURCE: Hi ! my 3 years old fridge Samsung Rs2630ww
lashing light stating that its too warm .. compressor probably is not running / power is ok or lights would not be on . look for a bad relay . somethes you can here clicking in back.
SOURCE: samsung rs2630Ww. internal refrig fan blower not working and water dispenser not working.
This problem could be caused by the
motherboard having defective relays, bad fan motor=> DA31-00103A Fan Motor Sounds like
someone will need to examine the fan motor and test the voltage to the fans
inside and outside the refrigerator. You will need to have this done to eliminate
what the cause is. Both condensor and evaporator fan motors are the same part=> DA31-00103A Fan Motor Let me know and I will explain how to remove, test or replace the
freezer/evaporator fan motor, wiring or motherboart. Thanks Sea Breeze
DA31-00103A
DA31-00103A
