Or anyone with the manual could be of help
SOURCE: how to clean juicer
i had the same problem and figured out an easy way to open it without the tool. DO NOT take out the screws. I simply used chop sticks. I put one in each small hole and held the chop sticks in an X and turned the top counterclockwise!
SOURCE: manual
Hi - You can download the manual from the link underlined in blue below:
je700 juicer
Please update the question & let us know if the information given was useful to you - Good Luck!
SOURCE: Manual for Juicer
Jack Lalanne Juicer Operating Manual 4 pages
http://www.myeasypics.com/is.php?i=488927&img=jack_lalanne_operating_manual__0001.jpg
http://www.myeasypics.com/is.php?i=488928&img=jack_lalanne_operating_manual__0002.jpg
http://www.myeasypics.com/is.php?i=488929&img=jack_lalanne_operating_manual__0003.jpg
http://www.myeasypics.com/is.php?i=488930&img=jack_lalanne_operating_manual__0004.jpg
SOURCE: need instruction manual for Jack Lanne Juicer
SOURCE: given a kenwood je500 juicer
Hi all!! I also had same problem, but found that under the juicer there was a 'quality control' sticker hiding a small **** in the plastic. this **** is in line with the motor shaft which also has a slot in it. use a small thin screwdriver to hold the shaft while turning the basket anti-clockwise and remove. easy as that, will post a video later when I have a little time to do so.
Bruno Man
