Hi, When I go to download a movie the following error is coming up through safari. Safari can't open file because no available application can open it. How do I fix this up.
This seems to be a common problem with a lot of people. More often than not, it's because someone has installed MacKeeper or CleanMyMac, and these two applications have installed browser re-direct software.
First point of business: You don't need either of these two pieces of software. Use AppZapper to remove these applications. Now here are the steps that should get you back up and running:
Restart your computer holding down the Shift key. That will boot your computer into Safe Mode
Once it's up, open Safari... it should open fine in this mode.
Download a backup browser like Chrome or Firefox (Firefox also installs a bunch of junk that you may not want) for future safety.
Google "Adware Medic" (link below) and download the app. This is a small AppleScript that searches through your system to find the items that are causing Safari not to open.
Download and open the .dmg file and drag the app to your Applications folder.
Run the app and follow the instructions for removing the adware/browser re-direct software.
Restart your computer as normal.
This should bring your system back up to par...
... and stop downloading and installing things you don't need! :-) AdwareMedic
If you have no browser of any kind, you will be hard-pressed to download one or redownload your extensions. If you have a Time Machine backup, open applications folder, activate TimeMachine then select Safari and Restore. If this isn't available I recommend you get a Time Machine backup, use it, then boot up to recovery. (Restart, hold Command-R) Reinstall your OS. This will do so without deleting personal data, and will restore Safari, or at least give you a version of Safari that can be used to download the real deal. Good Luck.
Molly As it says the file needs an application to open it, what type of suffix does it have on it by this I mean does it have either .zip, .jpg, .doc, .exe or something else on the end of it. This would identify what application you need to open it. Do you know what the file is you are trying to download? If you could tell me what type of file it is I should be able to help you.
By default, Safari does not allow you to download files to your device, this is the same for other browsers. One solution is to jailbreak your iPhone 4, and then install Safari Download Manager from the Cydia store.
To jailbreak your iPhone:
Ensure you are running firmware 4.2.1 or above (Settings>General>About)
If not, then launch iTunes, click on your phone, and update the firmware.
Download Greenpois0n from: http://greenpois0n.com/ (download links are on the right hand side)
Extract and run the Greenpois0n.exe and follow the instruction very carefully.
After your device has been jailbroken, open Cydia, and search for "Safari Download Manager"
Pay the required amount and proceed with your download, it should automatically set up.
Restart your phone to be safe, and you should now be able to download any file.
Updating your Safari is really simple.
First, open your Safari, and paste the following in the address bar:
http://support.apple.com/downloads/#safari
Next, press on the first download button and follow the instructions.
omerk.
hi yuvraj, i am happy to assist your, its not so hard to install safari just copy and paste the link below :-
http://www.apple.com/safari/download/
Before downloading they will ask what type of OS you have, and your Mail ID, and your area just fill it up and click download button, your download will start and it will save in your system.
TO setup Safari browser check this video its will be more easy
You-Tube video "aC-kFW4Lx2k" placeholder Good luck ! if you think your problem solved don't forget to rate
