Tivax Tablet MITRAVELER7D4 Logo
Larry Beattie Posted on Mar 10, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I get my micro sd card to work on my MiTraveler tablet
Installed micro sd card, the tablet reconizes it but I can't load anything on it
JEM
Level 3:
  • Master 406 Answers
  • Posted on Mar 10, 2015
 JEM
Master
Level 3:
Answers
406
Questions
Helped
149246
Points
2858
You will have to add an app at the play store. There are many, one that I have used is called send to card. Remember to turn off your device before removing your sd card.
https://play.google.com/store/apps/details?id=ru.gelin.android.sendtosd
My tablet isnt recognizing the micro sd card I installed
Hi u don't mention make or model of tablet
this makes it very hard to check if u are using an SD card to suit you're tablet If u go over the maximum GB..it will not work..cheers
I have the panasonic Sc999bt tablet. I bought a 16 gb micro sd card, when i try to download anything,it says internal storage full. Please help
Hi. Ok you're tablet has 8 GB of memory & 1 GB of RAM ::: u can delete data u don't use this will free up some memory :try to transfer you're movies & data to you're SD card :::::buy a 32 GB SD card if u need it .cheers
How do i load photos from sd card to samsung sm-t560 tablet
Insert sd card into tablet if it is a micro sd. If its a full size sd card you need to transfer files either to google cloud or other sharable app and transfer them that way... Like picassa app.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/daniel_6d8155c5b1755ec1
I have hipstreet pulse tablet how do I get y apps to go onto my micro sdcard
You don't. Most apps will not load onto an SD card. This is because that many SD cards are not fast enough to support the app's needs, and also the app writers don't go to the trouble of writing apps to be loaded on SD since not every tablet has one. SD cards are primarily for the use of storage of photos, music, and videos. A few apps CAN, if designated, store some data and cache info on the SD, but your issue should be with the tablet makers for not putting enough memory in the tablet itself in the first place. This is how they save money.
How to down load films to a 32 GB card Hudle2.Thanks
OK, to accomplish this you need 2 hings:
1. A micro sd card. (Which I gather you already have one)
2. File manager installed in your tablet.
Now, if the tablet support micro sd card, you are all set. Download the file manager, it could be Astro, ES File Explorer, etc...
Once installed, open the file manager. The tablet storage, which is known as internal storage, it is display as sdcard/storage (or sometimes as internal storage). Once you tap the internal storage, everything that is installed in your tablet will be display; (Android, DCIM, etc...) Now you need to look where are the pictures or films saved at. It is usually DCIM/Camera. Once you have found the pictures that you want to move or copy, long tap the films, depending on the file manager app, you must tap copy or move (NOTE: Since every file manager is different, some takes a little bit of extra steps, others requires for you to open a menu). Once you had chose to copy or to move it, look for the external sd card location, which will also be located at sd card/storage/ (32gb external storage) and choose this location to paste your films or pictures.
Another way is by using a computer. Make sure that you have all the drivers needed for the computer to recognize your tablet, you also need the usb charge cable. Once the computer recognize it when the tablet is plug in to the computer, open it by double clicking, there should be 2 storage display under the tablet folder: Internal storage and 32gb. external storage. Open the internal storage, look for where the films are saved (just like I explained with the file manager), choose the films that are to be move or copy, and jus drag and drop or press ctrl and C to copy, go to the external storage, open it and press ctrl and V to paste.
How do I transfer from nand to sd
Hi
If your SD card is not recognised there are possibilities:
1. The manual - I'l give the link later in case yours is mislaid - only mentions "Micro SD" up to 32Gb. Sometimes these cards can be the SDHC category and these are not always accepted in devices designed for SD only. They look identical so make sure yours doesn't say SDHC.
2. The file format on the card can be significant. It needs to be a format compatible with the phone. If you have no other data on the card, it might be easiest to see if the phone will format it.
3. Of course it might be a faulty card - can you test it elsewhere?
The link for the manual mentioned above is here:
Proscan Media Tablets eBooks ReadersInstructions Manuals Quick Start...
Its about 15th down the list and will download direct to your computer.
With regard to downloading from nand to SD card, is this essential? If you have a micro USB to normal USB, then you should be able to use a computer to take data from the nand. The nand would show up as a drive in "My Computer".
Hope this is helpful, if so would you please register that with Fixya
Cheers
How do you transfer pictures to micro sd card on Zeki 7" tablet
well if youre device doesnt have a slot for the sd card, then you will need the right adaptor cord sync with another device
2answers
How do I get my external SD card to work in my tablet?
Check the GB on the SD card. Perhaps you need more GB. Try a 16 GB
Top Tivax Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Tivax Tablet and eReader Expert? Answer questions, earn points and help others
