Tried turning on the tv and initially you could hear sound but there was no picture. The green led was flashing one long flash followed by four shorter flashes then repeating that. Now I try and turn the tv on and there is no sound either and the led is just constantly flashing. Any help with this would be much appreciated.
Cheers
I had exactly the same problem When the TV was switched on all I could
see was a flashing green light. After cheching the TV internals and not
seeing a problem including the power supply unit which looked and
checked normal. Here is what I did to get M TV working again.
Disconnect it from the power supply. Hold down all the buttons
simultaneously i.e. the on/off, the volume, the programme, menu
buttons, all of them simultaneously and Plug it into the power supply
again.
Lo and behold My TV jumped back into life after an absence of about 4 weeks.
Try it yourself exactly as above.
Best of luck.
Irishfreethinker
Thanks very much for the quick reply,
I have changed both of the cables on the tv they were justa standard aerial connection and a scart from a digital box. The tv still has no sound or picture and the led power indicator on the front of the tv is just flashing constantly and rapidly.
What ios the input source to the TV is it AV? if it is check the Video cable try interchanging the coloured cables....secondly if the sout\rce is AV try touching the core of the input and watch for a flicker;if it flickers it implies that the TV is ok but the input source is faulty. Please clarify input source??
