You need to pull the crown out 2 clicks and rotate to set time.
1 click and rotate for day/date functions.
Push in fully to lock settings and resume time keeping.
You can pull out the stem on the side there is a halfway setting one click out, turn one direction for day and other direction for date, two clicks out sets time.
depends if you want the same factory crown or just one that looks nice but not the official crown , but crown , if stem is not broking around 15 - 20 dollars to replace, crown and stem around 30 4-5 dollars to replace.
Many watch companies are including extra clasps on the bands so customers can adjust the band easier on their own. Check the bottom of the band for those.
If not I suggest going to a reputable watch repair shop and have them do the adjustment for you. It will save you time and frustration of trying to do it yourself. If a screw or pin drops and you cant find it you may end up having to reorder them from Anne Klein!
I would recommend going to a watch repair shop for this. Depending on the style of bracelet there are a couple solutions. I would suggest a shop familiar with or that carries Anne Klein. Most repair shops will have extender links and clasps. If you have a fashion watch that doesn't have a typical clasp or bracelet set up a Anne Klein dealer will be able to better assist you in getting a solution from Anne Klein.
Precision Time has Anne Klein and they do a fair job of getting parts through their repair center. You can visit their web site at PrecisionTimeCo.Com.
You do noy need an exact Anne Klein band as all watch bands are made to specific measurements. You have to measure the width of the band (the end attached to the watch) and buy any type of band you like, just make sure it is exactly the same width as the previous band. In case if you have the Anne Klein clasp or buckle, you have to measure the other end of the band as well and by any band you like, but in this case you need to match both ends of the band. Clasp or buckle are easily refitted to the new band and nobody knows that this is not an original one. Do not forget to rate, please.
