Black & Decker String Trimmer Cordless 12" 18V Logo
Posted on Jul 09, 2009
Cord is rapidly "minced" up
Cord is chopped into small pieces in 2 minutes
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jul 09, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
329
Points
0
PW1600 Black and Decker pressure washer - works for about 15 minutes steadily then quit - will not work again - power - test/reset is o.k. - Help!
1helpful
How to check the electric brake on a dewalt 706 type 1 chop saw
The power cord can get a break in it. Try moving it when this happens. Otherwise, the plug can fall out of the outlet. Sometimes the switch goes bad.
Jan 25, 2015 • Dewalt Saws
tip
Perfect party dips, all made easy in a slow cooker
The best part about a slow cooker is that all you have to do is drop the ingredients in and let them simmer for hours.
Here are some of my favorite dips to make for a get together in my slow cooker.
Spinach and Artichoke - Cook on high for two hours
24 oz. frozen Spinach
2 8 oz. package Cream Cheese
1 cup shredded Parmesan
2 cups Mozzarella
2 14 oz. cans Artichoke Hearts Chopped
1 small Onion diced small
1 Tsp. Garlic Powder
1 Tbs. Horseradish
1 Tsp. Chili Powder
Bacon Cheese Dip - Cook for three hours on high
1 Package Bacon, cooked and chopped
1 16oz Package Cream Cheese
4 Cups Shredded Cheddar Cheese
2 Teaspoons Worcestershire Sauce
1 Teaspoon Hot Sauce
1 Cup Half n Half
1 Teaspoon Minced Onion
1/2 Teaspoon Dry Mustard
Salt to taste
Caramel Apple Pie Dip - Cook for five hours on low
5 cored, skinned and chopped Granny Smith Apples
1 Teaspoon Cinnamon
1 Teaspoon Allspice
1 (14 Oz.) Container Fat-Free Caramel Dip
Buffalo Chicken Dip - Cook for three hours on high, add cheese at the end
1 lb cooked chicken, shredded (can be store bought rotisserie)
8 oz. cream cheese, cubed
1 cup ranch dressing
3/4 cup Frank's Red Hot Wing sauce (The wing sauce is thicker and hotter than the regular)
2 cups shredded cheddar cheese
on Oct 14, 2013 • Cooking
Need recipe to make pasta
Tips for Optimum Pasta
The dough should be evenly kneaded, and slightly moist to form a soft malleable dough. The dough should have the consistency which is not too dry or too moist.
The dough is too dry if it has a powdery, grainy consistency and breaks into small chunks. Add more liquid (water or vegetable juice) by the teaspoon until it has formed a smooth, malleable dough that is not sticking to the sides or the kneading spiral.
The dough is too moist if large lumps of dough remain stuck to the kneading spiral. Add flour by the teaspoon until it has formed a smooth, malleable dough that does not stick to the sides or the kneading spiral.
If you add a little bit of olive oil to the pasta dough, it will slide better through the outlet openings of the pasta attachments.
For the pasta dough, you can use both normal household flour as well as wholegrain flour, gluten free flour, or flour made from durum wheat semolina. Different types of flours will require a different amount of liquids. Reserve some liquid and add it slowly for best results. Document your process so you can repeat it in the future.
Vegetable juices made, for example, from spinach, carrots or tomatoes are ideal for adding color and nutrients to your pasta.
Sprinkle flour on your pasta directly as it emerges from the outlet opening and place it down separated on a smooth floured surface to dry. This will prevent the pasta from sticking together.
Cooking time for fresh pasta is much shorter than for dried pasta from the supermarket; 2-4 minutes is usually sufficient. Thinner pastas, however, may require an even shorter cooking time. We recommend you check the pasta at regular intervals until the pasta is "al dente".
Fresh pasta can be kept for 1-2 days in the fridge and frozen in the freezer for as long as 6 months. To stop the pasta from sticking, you should lay the pasta out to dry for 1-2 hours before you store it in the fridge or freeze it.
Pasta recipes
GARLIC PASTA
Add 2 cloves of garlic (crushed or pureed) to the liquid in a full load of pasta. Cook and serve with sauce and cheese.
TWO MINUTE CLAM SAUCE FOR LINGUINE
Pasta: Linguine or Spaghetti
3 Tbsp.
Olive oil
2 Tbsp.
Garlic - finely chopped
1 can
Clams with juice
3 Tbsp.
Oregano
1/2 cup
White wine (optional)
1/2 cup
Prepared pasta sauce (optional)
Fresh ground pepper (to taste)
Crushed red pepper
Saute garlic and clams in olive oil. Add oregano, pepper and crushed red pepper to taste. If desired, add white wine and/or prepared pasta sauce. Pour over pasta, garnish with minced parsley.
FETTUCCINI & CHICKEN
Pasta: Fettuccini (with 2 Tbsp. olive oil or butter)
4 large or 6 small pieces of boned chicken cut in chunks
2 Tbsp.
2 Tbsp.
Italian seasoning
2 Tbsp.
Parsley
Olive oil
Salt & pepper
Bake or saute chicken in olive oil with garlic and seasoning until done.
Place chicken on freshly cooked fettuccini and serve hot. For variety,
add sauteed mushrooms and/or bell pepper. Add Parmesan cheese.
HUNGARIAN PAPRIKA PASTA
To a regular full load of pasta add 2 tablespoons of paprika to the liquid
and stir well before adding to the flour as it mixes.
SPINACH FETTUCCINE IN CREAMY DILL SAUCE
Pasta: Fettuccine, Linguine or Rigatoni
Great with any pasta, but this is very tasty with spinach pasta! Make your liquid for the pasta with fresh spinach juice or mix spinach with a small amount of water in a blender and strain before adding to the egg and oil mixture.
1 Tbsp.
Butter
1 tsp.
1 cup
Heavy cream
1/4 cup
Parmesan cheese
2 Tbsp.
Fresh dill
1/2 cup
Tomatoes - diced
Salt & pepper to taste
Melt butter with garlic in pan. Add cream, salt, pepper, and Parmesan cheese. Stir until cheese is melted. Reduce heat, add fresh dill and diced tomatoes. Remove from heat and gently pour over pasta.
RUSSIAN BORSCHT P ASTA
Measure 2 cups of flour. To your liquid ingredients add oil plus egg. Use beet juice instead of water and 1 teaspoon ground sour salt. Serve as a side dish with sour cream.
PASTA WITH SUN DRIED TOMATOES & PINE NUTS
Pasta: Spaghetti, Fettuccini or Linguine
1/4 cup
Olive oil
1 clove
2 Tbsp.
Italian herbs
1/4 cup
Sun dried tomato - cut tomatoes in 1/8" slices
1/4 cup
Pine nuts
Saute garlic in olive oil, then add herbs. Remove from heat and stir in sun dried tomatoes. Toss lightly with cooked pasta. Top with pine nuts. Serve with Parmesan cheese.
BASIC PASTA WITH FRESH TOMATOES
Pasta: Any of your favorites
6 Tbsp.
Olive oil
2 Tbsp.
Garlic - minced
2 Tbsp.
Basil - fresh, minced
1 cup
Ripe tomatoes - diced
Parmesan cheese
Saute garlic. Add basil to hot skillet. Remove from heat and stir in fresh diced tomatoes. Pour lightly over fresh pasta. Serve with Parmesan cheese.
ARTICHOKE & BUTTER PASTA
Use 2 measuring cups of flour. Fill to "Oil+Egg+Liquid" line with: 1 egg, 2 tablespoons melted butter and fill to top of "Oil+Egg+Liquid" line with liquefied (pureed) artichoke hearts (cooked, or cooked and marinated) after straining artichoke juice through sieve. Serve with remaining artichoke hearts.
SOUTHWEST CHILI PASTA
Use 2 cups of bread or semolina flour. For your liquid, use: 1 egg, 2 teaspoons oil, 1 tablespoon chili powder, 1 teaspoon salt, 1 teaspoon onion powder and fill with tomato juice to top of "Oil+Egg+Liquid" line on your measuring cup.
LEMON PEPPER PASTA & SHRIMP
Pasta: Lemon Pepper Linguine, Spaghetti or Fettuccine
1/4 cup
Olive oil
1 lb.
Fresh shrimp - peeled, deveined and butterflied
2 Tbsp.
Garlic - minced
2 Tbsp.
Oregano
1 Tbsp.
Lemon pepper
1 tsp.
Minced parsley
1 cup
2 Tbsp.
3answers
How do you make sweet potato dumplings?
Spray a 13x9x2 inch baking dish or pan. Take one can of biscuits and peel each one in half, (you'll have 16 pieces). I have used crescent roll dough, but biscuits are easier. Press biscuit pieces to flatten them and place sweet potato to one side of the biscuit. I use frozen sweet potato patties but, you can use canned sweet potatoes (mash them good) for this recipe. Cut the patties in half or use 1 heaping tablespoon of mashed sweet potato and put the sweet potato to one side of the biscuit. Sprinkle with your spices of choice ( pumpkin pie spice,apple pie spice or even just cinnamon). Bring the one side of the biscuit over the other side and press the edges together to seal it really good. Line your dumplings in two rows in your baking dish, sprinkle with your spices of choice. Now, in a saucepan combine 2 cups of water,2 cups of sugar,1 1/2 sticks of butter (or margarine), 1 tablespoon of corn starch, 1 teaspoon of vanilla. Whisk together and put on a medium-high heat until just boiling-- all the time whisking ( to prevent lumps). Soon as it boils pour it over the dumplings. Bake at 350 degrees for 45 minutes. When you pull it form the oven sprinkle with cinnamon and serve. If there is any left-over (HAHA!) It reheats well and is still SO_O_O_O fantastic!
Jul 11, 2014 • Cooking
How do you make mint ice cubes? I heard that mint doesnot freeze very well.
You can just put mint leaves into the base of ice cube trays and add water and freeze. Because mint is a very soft herb, some people find that it doesn't freeze so well. Another option is to blend the mint in a processor and freeze it in cubes ready blended. This is good for recipes that call for finely chopped or minced herbs rather than whole leaves.
Feb 18, 2013 • Home
Does pressed garlic get you as much garlic from a clove as chopping it?
No, there will always be less garlic when you press it. There is the most garlic from a clove when it is minced with a knife.
Feb 04, 2013 • Home
How to cook hamburgers - temperature, etc.
Prepare Patties
1. Put minced scallions and chopped mushrooms in bowl.
2. Add red wine vinegar.
3. Add ground beef to bowl.
4. Mix everything together with your hands.
5. Flatten the beef into four patties that are 1/2-inch thick and 5 inches in diameter.
Cook Patties
1. Set stove-top grill or burner to medium-high.
2. Preheat nonstick frying pan. The pan is the correct temperature when a drop of water dances on its surface rather than sticking to it.
3. Place patties in the pan and cook for 2 to 3 minutes.
4. Flip patties and cook for another minute, and then add sliced cheese to the tops of patties if desired.
5. Cover pan and allow burgers to cook for a final 2 minutes. Cook 3 to 4 minutes for well-done burgers.
6. Remove hamburgers from pan and place in hamburger buns.
7. Add condiments and toppings such as ketchup, mustard, sliced tomatoes, lettuce, red onions and pickles.
Share some please! ü
Thank youfor visiting FixYa! We answer yourconcerns promptly for FREE. Please spare a few seconds toclick on YES button in return. Havea good one!
Jun 12, 2011 • Vacuums
2helpful
GL 315 strimmer chops the line up into small pieces and goes through a reel in minutes
the spool control teeth have worn out and is continuesly feeding line take out spool look at teeth in head if good replace spool if not need new head and spool
Jul 07, 2009 • Garden
Top Black & Decker Garden Experts
Thomas Perkins
Thomas Perkins
Mike Cairns
Mike Cairns
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
