SOURCE: LG Flatron L1550S power light blinks green.
shorted components on the circuit. send it to a repair shop if you don't have experience on electronic troubleshooting!!!
SOURCE: My LG Flatron L1511S 15 in. Flat turned into Power Saving mode when I plug in serial cable!
if the monitor showing powersaving mode, monitor is ok. It must be your CPU complaint.
SOURCE: Analog Out Of range (LG Flatron L1750T)
some games need high resolution. Monitor resolution not supporting for this game.
Powersaver mode showing when the main PCB of the monitor failed. check this link to get the service center info
http://www.lgservice.com/
SOURCE: how to disassemble a LG LCD monitor
Hi...there,
There are 2 ways to opened it... 1: from the back, removed 4 screws and get a good grip on both open edges and pulled. Need to give it some force to it. 2: The other, it from the front bezel. First laid it face up and placed a piece of cloth or micro-fiber cloth over the screen to prevent smudges or damaged from the 4 knuckles . Then use both 8 fingers to grasp onto to edges of a bezel and lift it up with some force to it. Do the same on other side Good luck!
SOURCE: How can I restore factory settings on our LG Flatron LCD Monitor?
press menu button it is in middele of lcd.
Ten go to setigns and u can fine reset buton press ok.
