Have tried several different methods as recommend but no success.
Good Morning Rolf, thanks for your post!
Based off the information you have provided your Electrolux wall oven/microwave combination is stuck in demo mode. The best way to remove demo mode from your wall oven/microwave combo is to hold the oven light button and the on/off keys at the same time and you should be able to toggle in and out of demo mode. Hopefully this is helpful. -Matt
Testimonial: "nope that did not work but here is what did. 1)Power off and back on at main. 2)Press the timer + button and the oven light button simultaneously for a few seconds. 3)Wait for the audible sound 3 beeps 4)Voila out of demo mode."
Hi Sharon Knight - Does any part of the range work? I would recommend verifying that a fuse is not blown or a circuit breaker tripped. Test the power outlet with a lamp, hair dryer, etc. Another questions, does "Loc" appear in the display if any button is pushed? The Oven Lockout feature automatically locks the oven door, prevents the warmer drawer and most oven controls from being turned ON. If so, press and hold CLEAR/OFF for 3 seconds. A beep will sound. LOC will clear. The "DOOR LOCKED" will continue to flash until the oven door has completely unlocked. Does the clock display "Sd" or "dddd"? If so, the clock is in sales demo mode. Press and hold the "BAKE TIME" button for 6 seconds to exit sales demo mode. If this does not prove to be successful, contact a professional to have EOC diagnosed and/or to confirm that there isn't a wiring failure.
I tried that it did "not" work but here is what did work for my model.
Power off at main and back on.
Set the correct time on clock (essential)
Press the timer + button and oven light button simultaneously for a few seconds
An audible beep 3 times and your out of demo mode.
