SOURCE: GE electric range with self cleaning oven. When
try to unplug power from wall and wait 30 min,then turn on
SOURCE: self cleaning oven troubleshooting
turn breaker off then back on put back in self clean the cancel it
SOURCE: AEG single oven - clock runs for 12 hrs , buzzes
you must setting the count down timer instead of time of day. to set time of day. press centre button 4 times lamp flashes in bottom righthand of display. use + and - to get correct time after 10 secs time will lock in. to check you have not set count down press centre button 3 times lamp flashes top right corner of display if not at 0000 use - button to get to 0000 leave 10 secs then should revert to time of day. also check you have not entered cooking time. press centre 1x this also should read 0000. hope this helps
