Question about Dyson DC59 Animal Bagless Cordless Stick Vacuum
I have had three filters for my dc59 but each of them fall out if the cleaner is turned on its side.Isthere anything I can do to prevent this?
Each of the filters are the same . They are not designed to locate in the cleaner hole.
  • Official Brand Answer
  • 2,572 Answers
Hi there, it's Jack at Dyson.
DC59's washable pre-filter is held in place in the top of the cyclone pack by the black rubber seal around the top of the filter. It should fit snugly, but should also be very easy to remove for its monthly maintenance with no screws or catches to undo.
When the vacuum is running, the filter will be held in place by the machine's powerful suction. When you're not using the machine, avoid holding it sideways or inverting it to help ensure the filter remains in place. When you're replacing the filter after it's been washed and allowed to dry, it should also help to press it firmly back into place.
If you'd like any additional advice I would encourage you to contact the Dyson Customer Helpline directly so we can take some further details. You can reach us on 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Posted on Mar 09, 2015
Testimonial: "Thank you for your reply ,jack. As I can read,you, are saying that nothing physical is holding the filter to the machine, but when running the suction should hold it in the machine."
  • AskDyson
    AskDyson Mar 10, 2015
    Hi David, the black rubber seal around the top of the filter forms a friction fit with the top of the cyclone pack. This should hold the filter securely in place even when the vacuum isn't running. However as mentioned, it's best not to carry the machine sideways or upside down to help ensure the filter can't work itself loose. Best wishes, Jack - Dyson Online Customer Support
  • 365 Answers
Call a Dyson service center.
6ya staff
SOURCE:
Problem with Miele Maverick telescopic wand - the plastic sleeve on the tube cracked and when I slide it back in the other tube won't fit In.
Call on the 15 year warranty!
Miele Vacuum Cleaner Accessories
https://www.miele.ca/en/c/vacuum-cleaner-accessories-1839.htm
All product benefits at a glance - Vacuum Cleaner Accessories. ... The Miele AirClean filter system filters more than 99.9% of all fine dust particles. ... Genuine Miele accessories are specially designed for your Miele vacuum cleaner. Missing: maverick
Spare parts & accessories - Miele
https://www.miele.ca/en/professional/spare-parts-and-accessories-135.htm Spare parts & accessories. At the end of the production of your appliance, Miele gives you a supply guarantee of up to 15 years for functional replacement parts. In addition, it is often possible to deliver original replacement parts for important functions. Delivery option up to 15 years following production end. Thanks to their ... Missing: maverick
Where to Buy - Miele.ca
m.miele.ca/en-CA/WhereToBuy.aspx Looking for: Appliances. Vacuums. Vacuum Repair Centres. Miele Certified WetCare Professional. Depending on what you are looking for, you might want to consider further refining your search. Learn more. Miele Retail Gallery. Miele Innovation Centre. Find Locations. Back ...
Apr 08, 2018 | Miele Vacuums
Changed filter and bag. no suction, dust comes out of the front of the vacuum covers the vacuum cleaner.
If it is an upright vacuum cleaner you need to turn it over and remove the base plate. There are usually 4 easy turn tabs, or 4 screws. Under there on one side behind the brush, you will see a hole where the dust goes up into the bag. Yours will be blocked. Often a piece of stick, a hair grip or something blocks the hole and then the fluff builds up on it until fully blocked.
Let me know how you get on by clicking the COMMENT button on this post.
Dec 01, 2015 | Filter Vacuums
I have a Bissell preheat 2x which I have had for about 4 years. The cleaning solution and the water doesn't come out when I start to clean my carpet. I've unplugged the holes and cleaned the cleaner a
Clean the filters? Check your- User's Guide for locations. Or Contact Consumer Care at 1-800-237-7691
Filters are usually located under the Clean Water Tank Cap (looks like a screen) and The Flow Indicator Cap. Hope that helps.
Sep 09, 2014 | Bissell Vacuum Pro-Heat, Pro-Heat 2 6960W...
DC24 loss of suction when upright
blockage in the yoke or side pipe, remove head, use a finger to feel for the paper thats stuck inside, and remove side pipe to clear from the top of the yoke 5 min fix
Aug 19, 2017 | Dyson Ball DC24 Bagless Upright Vacuum
Mintcraft kitchen faucet # 630-553 leaking from small hole in back of faucet
The hole is very small in the tail pipe and when you throw food, grease, it clogs this hole either partially or fully. When this happens then the water runs all over the sink through the weep hole. Which is the worst design I ever seen. By hand unscrew the black compression nut. Get a pipe cleaner or piece of wire, clean out the tube and especially the drain saddle. Reassemble and problem should be fixed.
http://www.ibathtile.com/bathrooms-kitchens/Hansgrohe.html
Sep 14, 2011 | Vacuums
I just purchased a floormate. I can't seem to get it to spray cleaning solution.
Turn the cleaner off and then on again to determine whether the cause of no suction resulted from the activation of the automatic shut-off. There are two reasons a tank will automatically shut off. The first is if the recovery tank is full. Located on the lower front panel of the unit, the recovery tank can be easily emptied and replaced into position. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
Turn the unit on again and check the suctioning action. The second reason automatic shut-off could take place is if the handle was raised to an upright position while the motor was running. Should this occur, simply turn the unit off, wait a moment for the shut-off to reset, and turn it on again to continue cleaning.
  • 2 Make sure the filter and filter lid are properly positioned in the recovery tank lid. The cause of the problem could be that the filter or the filter lid were missing or were not in the proper position.
  • 3 Check that both recovery tank and/or solution tanks are locked in place and are positioned properly. The recovery tank is located on the lower front panel of the Floormate, and the solution tank is located in the front top panel of the unit. To remove from unit, press down on the release button and pull the tank downward and forward. Lift up on the tank latch lid and take out the tank lid. Empty the tank. Also check the tank lid screen for debris and remove any found. To replace the lid, align the tab that corresponds to the front hole of the tank. Snap the latches on the back of the tank. Insert the bottom of the tank back into the cleaner and push in and up until it locks in place.
  • 4 Observe whether filter is dirty. If the filter is dirty, clean the filter by turning the cleaner off and disconnecting it from the electrical unit. Take out the recovery tank and lid. Remove loose debris from the filter by wiping clean with a brush or tapping the filter over a garbage can. After this is completed, the filter may be rinsed clean for additional cleaning and then air dried before returning the filter to the unit.
  • 5 Check that the nozzle is in the proper position and locked. Locate the nozzle underneath the suctioning base of the unit. Make sure the latches are out and line up the middle section of the nozzle with the opening of the cleaner. Hold the nozzle in place while simultaneously sliding the latches inward to lock in
  • Mar 07, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
    I don't get much suction from the hose on my DC17 All Floors. I don't see any obtacles in the hose. The suction when upright is fine.
    The way your Dyson DC17 is designed, there is a suction divert mechanism that diverts the suction to floor when the vacuum cleaner head is pushed down, and then back to the hose when the vacuum is in the upright position. If you are getting suction from the hose when the vacuum is upright, but no suction after the handle is reclined, this is actually the normal function for the Dyson DC17.
    You can check to see if the filter is dirty. The washable filter on your Dyson DC17 is located directly underneath of the dust bin of the vacuum cleaner. After removing the dust bin, lift straight up on the part the bottom of the dust bin rests on. This is where the pre-motor filter is located for the DC17 models. If this filter is not cleaned on a regular basis, then it can start getting clogged, and you'll notice a loss of suction on the vacuum cleaner.
    If you have further questions, please visit the link below where you may download the instruction manual. There are some trouble shooting guides at the back of the manual that you may do to try and diagnosis this further.
    Dyson DC17 All Floors Instruction Manual:
    http://media.dyson.com/downloads/us/floorcare/manuals/dc17_opmanual_usa.pdf
    If this was helpful, please be sure to rate the repair as helpful by clicking on the thumbs up icons on the top of the repair.
    Thank you very much,
    Chris Jones
    GoVacuum
    Mar 23, 2010 | Vacuums
    Troubleshoot floormate spinscrub 800 floor cleaner
    The brushes are not designed to scub the floor, they only lightly touch the floor. Make sure the front nozzle is put on correcdtly. Make sure your filter is dry and clean. I wet filter will give poor suction down to the nozzel. Down load the manuel at Hoover.com. The model is located on the back of the unit. H3000, or H3010
    May 24, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
    Bissell carpet cleaner
    If water is spraying from the tool hose, then check the heater for a blockage. If the heater port is blocked, then the water can't flow back down to the spray nozzles, which could also be clogged. Most likely a clogged heater, it is in the handle.
    May 11, 2008 | Bissell 1699 ProHeat Clear View Upright...
    Dyson DC59 Animal Bagless Cordless Stick Vacuum Logo
    226 people viewed this question
    Top Dyson Vacuums Experts
    AskDyson
    AskDyson
    Nick Olsen
    Gerry Harvey
    Gerry Harvey
    Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
