Cell Phones Logo
A
Anonymous Posted on Mar 09, 2015
How do I change time and date on LG440G Tracfone?
Change from standard time to daylight saving time. Nothing on cell phone menus.
Linda Gentile
Level 2:
Habit-Forming:
  • Expert 72 Answers
  • Posted on Mar 13, 2015
Linda Gentile
Expert
Level 2:
Habit-Forming:
Answers
72
Questions
23
Helped
15508
Points
104
On my model, I go to menu, then calendar, then calendar will show up & you can use arrows at the top to pick month & year, then once you got the right month, tap on correct day. that is for the date.
The time should come up automatically when you turn on your phone. Mine even changes to correct daylight saving time automatically.
5 Related Answers
Anonymous
  • 93 Answers
  • Posted on Nov 04, 2007
SOURCE: Changing Time
well i have sprint and sprint does the change automaticly
Anonymous
  • Posted on Mar 10, 2008
SOURCE: Daylight Savings Time
I just turned it off and back on (I've ***** had to do that with a cell phone before - so I ***** thought to try it on this one).
Anonymous
  • Posted on Nov 01, 2009
SOURCE: how do you change the time?
they change automatically
Anonymous
  • Posted on Mar 15, 2010
SOURCE: LG600G did not update time for daylight savings time
I had the same problem. I simply powered it off, and powered it back on, and it had updated.
Anonymous
  • Posted on Mar 26, 2010
SOURCE: cell phone
AFIK - You can;t set the time, but when service is established with the cell netwoirk - the correct time is set then.
1helpful
The time on my tracfone. It did not automatically switch from daylight saving time to standard time.
Hello, Call tracfone with make and model of phone and cust. service will help you set it up right.
1 (800) 867-7183
Please rate my answer, Thank you.
Nov 03, 2015 • Cell Phones
My phone did **t change time automatically today. I turned it off and then back on deveral times, and still ** time change. what do I do?
What model cell phone are you using?
Most cell phones have an option somewhere in the menus to switch for daylight savings time automatically. Most likely, this option is turned off.
If you can tell me what model phone you're using, and who your cell phone provider is, I should be able to guide you to that menu option.
-Dyllan
Mar 09, 2008 • Cell Phones
1helpful
How to set time
Plug in the unit.
First, the month and date appear, then the
year, and then the current Eastern Standard/
Daylight Time appears in the display.
Press
TIME ZONE
Area number "2" appears in the display.
If you live in the Eastern Time zone, you do
not need to adjust the area setting.
Area number
Time zone
Atlantic Standard/
Daylight Time
(default)
Eastern Standard/
Daylight Time
Central Standard/
Daylight Time
Mountain Standard/
Daylight Time
5
Pacific Standard/Daylight
Time
6
Yukon Standard/Daylight
Time
7
Hawaiian Standard/
Daylight Time
Press
TIME ZONE
repeatedly until the
desired number appears.
The display returns to the clock about 4
seconds after the operation is complete.
Note
During the shipment and your first use, a clock
error may occur. In this case, refer to "Setting the
clock and date" to set the correct time.
When daylight saving time
(summer time) begins
This unit employs Automatic Daylight Saving
Time/Summer Time adjustment. The DST
indicator appears in the display at the beginning
of the daylight saving time (summer time), and
disappears at the end of it.
Daylight saving time begins at: 2:00 AM on the
second Sunday of March.
Standard time begins at: 2:00 AM on the first
Sunday of November.
To cancel the automatic DST/summer
time adjustment and to set DST display
manually
The automatic DST/summer time adjustment can
be cancelled.
Press and hold
DST
for at least 3 seconds while
the clock is displayed.
A beep sounds, and "Aut
OFF" appears in the
display to show that the automatic DST/summer
time adjustment is cancelled. The display returns
to the clock.
Notes
Daylight Saving Time depends on the law in
each country/region, and your area may not use
it. In such a case, cancel the automatic DST/
summer time adjustment before using the set
and set the time manually as necessary.
To activate the automatic DST/summer time
adjustment again, press and hold
DST
for at
least 3 seconds. A beep sounds, and "Aut
On" appears in the display to show that the
automatic DST/summer time adjustment is
activated. The display returns to the clock.
To change the display to the daylight saving
time (summer time) manually, see "To change
the display to the daylight saving time (summer
time) indication."
Setting the clock and
date
To change the setting manually, follow the
procedure from step
Press
CLOCK
for at least 2 seconds.
You will hear a beep and the year will start to
flash in the display.
Press
or
until the correct year
Press
CLOCK
Repeat steps
and
to set the month,
day and time.
After setting the time, two short beeps sound
and the clock starts from 0 seconds.
Pressing and holding
or
changes the year,
month or day rapidly.
When setting the current time, time changes
rapidly by 1 minute-increments up to 10
minutes, and then by 10 minute-increments.
While setting the clock, you must perform each
step within 65 seconds, or the clock setting
mode will be cancelled.
To display the year and date
Press
SNOOZE/DATE/SLEEP OFF
once for the
date, and within about 3 seconds press it again for
the year.
The display shows the date or year for about 3
seconds and then changes back to the current
time.
If you connect the AC plug to an AC outlet while
this unit is powered from the backup power
source, the current date and time appears in the
following order (the same as when the unit is
powered on after a power interruption).
"month and date" (about 1 second)
"year"
(about 1 second)
"current time"
saving time (summer time) indication
Change the daylight saving time (summer time)
adjustment setting according to the following
procedures if you have cancelled the automatic
DST/summer time adjustment.
Press
DST
The DST indicator appears in the display and the
time indication changes to the daylight saving
time (summer time).
To deactivate the daylight saving time (summer
time) adjustment, press
DST
again.
3answers
How do I change the time on my lgl34c
go to settings and select date and time.turn off automatic date and time and set the date and time to what you wish
Sep 27, 2014 • Cell Phones
How to change the clock on tracfone lg440G
To change the time on a Tracfone LG440G, turn the phone "off", then turn it back "on". If that doesn't work, turn it "off", remove the battery, reinstall the battery, turn it "on". Time should display properly. No way to change the time manually.
Change date & time on a LG440G tracfone
Turn it "off", then turn it "on". No way to change it manually.
Sep 30, 2013 • Cell Phones
9helpful
How do you change the time, date and location for the LG900G
From the number keypad, type 1809#*900# go to Eng Mode, and the very bottom option is Date & Time. In that menu, you can change the date, time(can change time zone/city in this menu), and daylight savings..
Just figured this one out myself.. Hope it helps!
Sep 27, 2011 • Cell Phones
19helpful
2answers
Unable to change the time.
MY W175 Automatically changed to dst. Had to turn it off and I dont remember if had to take the battery out or not, but when it finally picked up service the time was daylight savings time.
Changing Time
Top LG Cell Phones Experts
vince
Steve Sweetleaf
Steve Sweetleaf
nexrad_chris
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
