Have new ink cartridge how do I fit it
SOURCE: not recognizing new ink cartridge
We had the same problem and tried all steps Customer Service suggested each time; after several calls, it was determined we had a defective printhead... Kodak sent a new printhead, new ink cartridges w/ an envelope to return the ones I was using.
Apparently it's a common problem with this model; especially the earlier ones. Have had NO problems since the printhead was replaced.
I would suggest if you have recurring problems (even after Customer Service directives), call and ask if you might have a defective printhead.
SOURCE: Help with my Kodak EasyShare G610 printer
Have you tried cleaning the paper feed rollers with a slightly damp, lint-free cloth? You'll have to remove the paper try first. If that doesn't work you may have to remove the ink cartridge and tighten the roller. I had to call the Kodak technical support to get help with this. Hope this helps.
SOURCE: EasyShare G610 Ink only wanted.
Start here:
http://www.kodak.com/global/en/service/products/ekn033119.jhtml?pq-path=10734
Can I purchase the ink cartridge and the paper separately for my printer dock?...No, you cannot purchase the ink cartridge and the paper separately....FAQ
http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=10734/7269&pq-locale=en_US
SOURCE: Kodak G610 printer dock won's communicate with computer
You know I had this same problem for a while as well. The only solution I found was that I HAD to use the Kodak Easyshare software in order to print anything with it. (That was the case with my XP desktop and my Mac laptop...). But sometimes it still would not spool properly and would require unplugging the printer and plugging it back in to reset.
SOURCE: kodak #G600 printer dock/roller won't pull paper through
I read this solution to a problem someone else was having which was similar to my problem. I wiped off the roller with a damp cloth, made sure it was dry and that's all it took to allow the roller to be able to start to pull the paper through. - thanks for the help!
