Question about Garmin StreetPilot c550 GPS Receiver
Frozen screen cant turn my garmin c550 off
    Problem Solver:
  • 7 Answers
Facing the GPS system, remove the front cover with your nail or something sharp and under it you will find a reset button. If needed, refer to page 30 in the manual (see website below) for pictures:
www.tramsoft.ch/downloads/garmin/streetpilot-c550_owners-manual.pdf
Please don’t forget to rate my answer.
Posted on Nov 13, 2007
2 Suggested Answers
Anonymous
SOURCE:
Bogdan Gologan
  • 7 Answers
SOURCE: screen frozen
My garmin is frozen how can i rest the unit
with the garmin off, hold down the right bottom of the screen and turn the garmin on, it will then ask you if you want to perform a hard reset. Choose yes and that should fix your problem.
Jul 10, 2009 | Garmin StreetPilot c550 GPS Receiver
Cant enter pin or screen is frozen
Look near the SN # and press the reset button.
or
Nov 11, 2008 | Garmin Nuvi 660 GPS Receiver
GARMIN C550
hey u got to try 4 digit.. try to do it the most you cant and belive me u will unlock your garmin c550...after felling alot of times will go back to reset and it will unlock..good luck
Feb 26, 2008 | Garmin StreetPilot c550 GPS Receiver
Bluetooth connection
If you have tried to connect from the unit and from the phone, and neither finds the other, or they won't connect, it is possible the phone may not be compatible with the unit. Not all Bluetooth devices are compatible. Your best bet would be to go to Garmin's website and check the C550 for compatible phones and see if yours is listed.
Feb 25, 2008 | Garmin StreetPilot c550 GPS Receiver
Won't turn on after first time
saw this on a different forum.....I got one for xmass.....hope it doesn't happen to me!!!!!!!!
I apologize for the inconvenience. After further research with our engineers, a problem has been discovered on your C550. A file has been created to stop the unit from turning off and locking up. Please download the new file from your computer to the unit. The file is attached to this email along with instructions on how to get the file into the unit.
The following procedure will update the software in your C550 series and correct the power issue you are experiencing with your Garmin C550 series
1.) Let the Garmin sit without power for at least 24-48 hours.
2.) Plug the C5xx series into the your computer (using a USB port in the back of the computer) with the cable provided with the unit.
3.) After removing the faceplate on the front of the Garmin press and release the reset button. At this time the C550 series will reset and power on.
4.) Save the attached file included in e-mail from Garmin Product Support. Save this file to the desk top on your computer. Note: This will make it easy to find.
5.) Open the My Computer window (by accessing the start menu on the bottom left of your computer screen).
6.) Locate and open the Garmin Mass Storage device.
7.) Locate the Garmin folder and open.
8.) Open the remoteSW folder.
9.) Copy the file that you have saved to the desktop and paste it into the remoteSW folder you have just opened. Make sure that none of the files contained within the remoteSW folder is highlighted, or you will not be able to save the new file.
10.) A message window will pop up asking you to confirm that you want to replace the file; Select Yes.
11.) Disconnect the C550 series from the USB cable and let the unit restart. A message will appear on the screen stating "Updating PLD Software".
Note: the screen will fade out and go blank during this process. Do not be alarmed, this is part of the update procedure, and the screen will return to normal within seconds.
Dec 26, 2007 | Garmin StreetPilot c550 GPS Receiver
LCD Screen Faded Out
Dec 06, 2007 | Garmin StreetPilot c550 GPS Receiver
Screen frozen
Nov 13, 2007 | Garmin StreetPilot c550 GPS Receiver
Screen Image too light to read
Try tapping the power key while the unit is on.  This may activate a control for contrast and brightness.  Otherwise it's in the settings screen.  Try looking at the screen in bright sunlight it may be make the screen visible enought to see the settings.
Oct 14, 2007 | Garmin StreetPilot c550 GPS Receiver
Screen says memory full and it won't map a route! GRRRRRRR
Hi, Please do not shoot the messenger (me) but this is a known problem with Garmin GPS units. According to Garmin Tech Support, this only occurs on Garmin units with older firmware. (Personally, I am not convinced this is actually true. I no longer have my Garmin C550, which I personally liked the best out of all the GPS units I have owned or used. I will buy another Garmin, probably a Nuvi, when this silliness sorts itself out.) Anyway, you have two options, neither of them acceptable to most people, including me. 1)Perform a HARD RESET which will wipe out all data on your unit, including your favorite points, Bluetooth connections, and almanac data (satellite information). Your unit will then need at least 40 minutes, with a clear view of the sky, to update the almanac and reacquire its location. To HARD RESET, unplug your C550 from the charger and turn it off. With the C550 screen facing you, press the bottom right hand corner of your screen and hold in (relatively firmly) and then press and hold POWER. You need hold both constantly for at least 30 seconds. Follow the instructions on the screen. See if any of your personal information is still there. If there is none, then you might as well perform Step 2 below. 2)Download and Load New Firmware onto the C550. Upgrading firmware is relatively easy provided you have a computer. Visit Garmin's website (www.garmin.com). Go to "Support" .. "Updates and Downloads" and then click "Unit Software." Download the software called WebUpdater. Run that and follow its directions. The new Firmware (Software that is loaded into internal memory that does not need power to remember the information) hopefully will fix the MEMORY FULL problem. Good Luck and please post back if the fixes helped or not. I really want the new firmware to work so I can buy another Garmin.
Oct 05, 2007 | Garmin StreetPilot c550 GPS Receiver
Pin unloock
how do i unlock my garmin i never put i pin number but is asking me the pin is a garmin street pilot c 550 thank you
Sep 23, 2007 | Garmin StreetPilot c550 GPS Receiver
Garmin StreetPilot c550 GPS Receiver Logo
177 people viewed this question
Top Garmin GPS Experts
Marvin
Marvin
John Egan
John Egan
Janelle Schoonover
Janelle Schoonover
Are you a Garmin GPS Expert? Answer questions, earn points and help others
