Amazon Kindle Fire HD Logo
C
CHARLES R CARTER Posted on Mar 08, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Just purchased a Kindle Fire HD7. Start up instructions say to charge battery by plugging device into power adapter via USB cord. Is there another way to charge device since I have no plug which fits the adapter?
ka4iup
Level 3:
  • Amazon Master 4,062 Answers
  • Posted on Mar 08, 2015
ka4iup
Amazon Master
Level 3:
Answers
4062
Questions
0
Helped
1095834
Points
51404
An adapter should have come with your Kindle Fire HD7 when you purchased it. The USB 2.0 cord is universal, so you could plug it into your computer and charge it that way also (while the computer is on).
I am assuming that you checked to make sure you had all the parts. Included in the Box Fire HD 7 tablet, USB 2.0 cable, 5W power adapter, and Quick Start Guide
  • Ron Jones
    Ron Jones Sep 29, 2017
    The charge cable is mini-USB.
Kindle battery won't charge . Kindle doesn't stay open
Hello
If the battery isn't too far gone, here's how to revive it:
    1.Plug the device into the Kindle A/C adapter (not your computer) and let it charge for a few hours.
    2.If you still see the same Critical Battery screen after charging, unplug the USB cord, then hold the power slide to the right for at least 20 seconds.
    For any help or support just visit us: Kindle Fire Support
My Kindle fire won't move past the start up "kindle fire" screen. what is wrong and how do I fix it?
Hello
Reset the Device:
If your Kindle Fire won't move, this doesn't necessarily mean that it's "broken" or has a major problem. The Kindle Fire has a tendency to become "stuck," meaning that it looks like it's "off" when it's actually "on" but it will not work properly because it's locked up. To unlock the Kindle Fire, do a reset by holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to get the Kindle Fire up and working again.
Charge It:
If resetting doesn't work, it's possible that your battery is dead. Try plugging the Kindle Fire into the charger and wait about 15 minutes before trying to turn it on again. If the device refuses to start up, try resetting it again.
If it still won't move, it's possible that you have a dead charging cable. Alas, the cables that come with the Kindle Fire are not known for their longevity. Try charging the tablet with another cord that has a Micro USB connection and see if the device responds. There's no guarantee that the charging cord from your smartphone will work with the Kindle Fire, but it's worth a try. If you get a bit of a charge, then you'll know that your Kindle Fire needs a new charging cable.
Try a Different Power Source:
if the charging cable appears to be working but the tablet still won't move, try plugging it into a different power outlet or the USB port on your computer.
If all of these troubleshooting tips fail, your Kindle Fire may have a hardware problem that requires professional help.
Visit here:
Kindle Fire Support
3answers
Kindle will not charge perhaps it is bent so charger will not go completely in
Hello
If the battery isn't too far gone, here's how to revive it: Plug the device into the Kindle A/C adapter (not your computer) and let it charge for a few hours. If you still see the same Critical Battery screen after charging, unplug the USB cord, then hold the power slide to the right for at least 20 seconds
For any help or query visit us: Kindle Support
My Kindle won't charge
If the battery isn't too far gone, here's how to revive it: Plug the device into the Kindle A/C adapter (not your computer) and let it charge for a few hours. Be sure the charging light is lit -- sometimes a drained Kindle will stop charging a few seconds after you plug it in. Unplug and replug until the light stays on steadily, then leave it alone. Most of the time you'll come back to a restored Kindle. If not, go on to step 2. If you still see the same Critical Battery screen after charging, unplug the USB cord, then hold the power slide to the right for at least 20 seconds. Release the power slide, then immediately press and hold the Home key for another 30 - 45 seconds. Once the Kindle's screen begins to flash, release the Home key. The eReader will boot to recovery mode. To continue, press and hold the R key until the screen flashes again. After the device is finished rebooting, you may see the Critical Battery screen once more. If so, plug in the USB cord and wait for the Kindle to return to the Home screen. - See more at: http://www.laptopmag.com/articles/kindle-critical-battery-error#sthash.Rtxwp4El.dpuf
How To Restore Your Kindle If It Experiences Critical Battery Error
f you can't get past step 3, the battery might be too far gone. Contact Kindle customer service via phone (866-321-8851) to walk through extra troubleshooting steps. If they can't revive it, Amazon will usually replace the eReader for free. - See more at: http://www.laptopmag.com/articles/kindle-critical-battery-error#sthash.Rtxwp4El.dpuf
2answers
How long to charge kindle fire hdx when new
It should take under 6 hours for a full charge.
2answers
Why won't my Kindle Touch charge?
The Kindle touch are great devices for you reading needs. However, there are times when it becomes unresponsive and freeze on you. Amazon says it is because the battery isn't charged properly or does not have enough power on it. It is advisable to charge your battery first before trying to reset the Kindle touch/Fire. If theKindle still has issues, then try the steps below on how to reset your Kindle touch. Please note that you may lose your data during the reset process, make sure you have made a backup of your files before proceding. hard and soft reset
  • Make sure the Kindle is turned ON.
  • Press the Power button for 20-30 seconds until it turns OFF.
  • Wait for it to reboot, if it doesn't press the power button to turn it ON.
  • Your kindle should be back to a responsive state.this might help you..
2answers
1helpful
4answers
Kindle fire won't charge
You may need a new power cord or it is possible that your Kindle Fire's battery has died. If you noticed the battery life diminishing before it wouldn't charge this may be the case. Here is a site that has replacement batteries for the Kindle Fire:
3555A2L Battery for Amazon Kindle Fire D01400
3answers
Brought a used kindle dx and didn't get a manual don't know how to use or what buttons to push
See here: Amazon Kindle DX Support
Once you have the machine running to read anything, the Kindle user manual is a pre-installed eBook on the device and also available for free via the Kindle storefront in case the previous owner deleted it.
Top Amazon Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Jennifer Rock
Jennifer Rock
Are you an Amazon Tablet and eReader Expert? Answer questions, earn points and help others
