BT GroupJan 26, 2015 - Tablet with WD My Passport wireless on table ... Free up storage ... You'll be surprised how much storage space is taken up with things you ...
Trusted ReviewsAug 28, 2015 - To really clean up its act, you need to find a custom interface that ... Well, the standard My Tesco one doesn't let you alter the apps menu at all.
To set it up, tap the Child safety app icon on the hudl2's home screen. Now go ..... The easiest way to access My Tesco is to tap the T icon at the top left of the screen, ..... most space and choose to delete the apps if you no longer need them.
The Hudl has been notorious for battery issues.There are a couple of things that you can try:
Check the software is up to date - Tescos have issued a number of firmware updates to address such issues
Use a different charger - The tablet may show it is being charged, but it could be misreporting it due to a multitude of issues with the charge coming through
If neither of these help, I suggest sending it off to Tesco if it is still under warranty. As I said before they have had quality control issues with the batteries.
Hi. To transfer your photos from your computer to your Hudl 2, connect you charging cable to your computer. Make sure that your Hudl 2 is show under the 'My Computer' page of your folder section. Then select your phots and drag the into the Photos folder of you Hudl 2. This can be found by double tapping the Hudl 2 icon on your pc.
I hope this helped.
According to Salivat Gairdner, below is How to un-freeze your hudl.
Turn over your hudl and search for a hole. Once you've found it, find a pen or pin and push it in. The hudl's screen should turn off. Turn the hudl back on using the power button and your set!
How to fix the freezing bug
Tesco has released an update which includes a setting in the Display section. It should automatically install, if it doesn't go to Settings then to About Tablet. Click on System Updates and wait for the hudl to find the update, if it does find one - leave it be until the installation has finished. Once it's finished, go back to Settings then to Display. Click on Reset touch screen, this is what causes the hudl to freeze. Click on Reset screen and your done!
You should just be able to plug your HUDL in and it should begin charging. Check that the outlet you're using is providing power (try another outlet too).
I'd recommend getting in touch with Hudl directly should you need additional support, I've included their support page below:
