Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
SOURCE: canon powershot sd 750 not uploading
it is possible that your cable is defective, if you replaced it already with a new one the problem is in the unit usb output circuitry, there maybe a loose connection or the module inside is bad, profix is needed. I suggest that better get a card reader cause the price of fixing the problem is too much compared to purchasing a new card reader.
SOURCE: Can't upload pictures to computer
hello.. your problem is not your computer,, your problem is about uploading picture from your camera
make sure your picture want you to upload is jpg files type..the uploading picture is must jpg type of files,, you able to change the file type of your picture ,,, how to change? open your picture and save again with select file type choices
or the to upload using other internet connection or upload using other computer to chick if your computer is not your problem,,, thank you hope i can help you have a good day!!
SOURCE: Camera not recognized by computer
Oh, I had I this problem last week. My drivers were outdated and I used this software:
http://www.windowsdriverhelp.com/landing/driver/wdh/driver.php?key=nikon p80
SOURCE: I cant upload pictures from my polaroid t730 camera to computer
I can'tg upload pictures. I have a polarioid t11031 digital camera, and I have a USB cord ffor it, but my computer does not recognize it when I plug it in. I want to know how I can get the pitctures off my camera and onto my computer.
SOURCE: COMPUTER WON'T RECOGNIZE CAMERA TO DOWNLOAD PICTURES
Have you installed drivers for it from either online or a cd-rom?
Did it ever work and if it doesn't now, when did it stop working?
