Televison & Video Logo
Posted on Jul 09, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need codes for philips universal remote three buttons on top row left to right code search/DVD/power 2nd row TV/VCR/AUX/CBL/SAT 3rd row OPEN CLOSE/LEARN (center 4 arrows and enter)
Anonymous
Level 3:
Master:
  • Master 377 Answers
  • Posted on Jul 09, 2009
Anonymous
Master
Level 3:
Master:
Answers
377
Questions
0
Helped
121251
Points
1027
I have a ge universial remote i need the code fora dynex flatscreen tv dvd combo
1. Manually turn on the device (TV, VCR, DVD, etc.) you wish to program.
2. Press and hold the CODE SEARCH/SETUP button on the remote until the INDICATOR LIGHT lights, then release.
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device Button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
4. Enter the three or four digit code for your device using the number buttons in the GE Universal Remote. After your code is entered the INDICATOR LIGHT will turn off.
5. Aim the remote at the device (TV, VCR, DVD, etc.) and press the POWER button. Your device should turn off.
Note: If your device does not respond to the first code listed, If your TV, VCR, DVD, etc. does not respond after you have tried all the codes for your brand or if your brand is not listed, try searching for your codes by following the steps below. Codes for brands are located at the bottom of this link. http://www.directutor.com/content/ge-universal-remote-instructions
GE Universal Remote Codes and Instructions direcTutor
I need the codes for a GE universal remote for a Daewoo TV
Welcome to FixYa!
You can try the following GE Universal Remote codes for Daewoo TV:
0130
0004
0009
0100
0005
0138
0043
0140
0039
0252
0279
0444
0080
0042
0058
0017
0010
0126
0018
0127
0019
MANUALLY ENTERING CODES
3. Press and release the button for the device you are programming (TV, VCR, DVD, etc.). For AUX, press AUX then the device button you are assigning to AUX. The INDICATOR LIGHT will blink then remain lit.
If none of the codes listed work for your device try the Code Search method described below.
USING CODE SEARCH FUNCTION
1. Turn on the device you wish to program.
2. Press and hold CODE SEARCH/SETUP until the INDICATOR LIGHT lights, then release.
3. Press and release the device button for the device you are programming (TV, VCR, DVD, etc.). The INDICATOR LIGHT will blink once then remain lit. For AUX, press AUX then the device button you are assigning to AUX.
4. Press and release POWER until your device turns off. Wait at least 2 seconds between each time you press POWER. Important: You may have to press POWER up to 250 times.
5. When your device turns off press the ENTER button (Should your remote model not have an ENTER button, then press the OK button.) The INDICATOR LIGHT will go off.
Thank you for using FixYa!
Have a great day.
Jas247
Philips dvp3150v vcr/dvd combo "code" for universal remotes
try following codes
RCA universal remote controller:
021, 022, 062, 096, 124(VCR)
162, 356, 357(DVD)
Philips Magnavox Universal Remote PM335
130 226 330 536 631 734 738(VCR)
441 442 943(DVD)
many direct codes doesn't work ,code searching method all ways work better but irritating
STEPS:
1. Press and hold CODE SEARCH
lights, then release CODE
SEARCH.
2. Press and release the device
button for the device’s code
you are retrieving (TV,VCR or
DBS•CABLE). The INDICATOR
remain lit.
Note: For AUX, press DVD•AUX
then the device button for the
code you are retrieving.
3. Press and release CODE
SEARCH. The INDICATOR
4. Starting with 0 on the keypad,
press the number buttons in
order (0-9) until the
INDICATOR LIGHT blinks.
5. The number which causes the
INDICATOR LIGHT to blink is
the first digit of your code.
6. Repeat step 4 until you have
retrieved all three numbers in code
NOTE
if any of the above works note down code used in small bit of paper and place it in the battery chamber(safe place)
2helpful
2answers
How do i search for an unlisted code for my universal remote?
This is the web site where I found the codes for mine, http://www.remote-codes.com/universalcodes.htm
Hope this helps, if not, let me knoe the model # and I can assist further...
5helpful
2answers
I have a vextra universal remote control and need the code for a colby dvd player
How to auto program this remote
1. Turn on the device to be programmed.
2. Press and hold SET for three seconds
3 Press the corresponding Device Button (TV, SAT, VCR, DVD,CBL,Audio)
4. Aim the remote at the device. Press the power button once and release. Each time the Remote searches for a code, the device button LED flashes twice. When the device turns off, immediately press ENTER to save the code (before the device button LED flashes again) This could take several minutes.
I have an older Axession Samsung 4 device remote, I need codes.
have you already found the way for that old axession?
please answer to [email protected]
thanks
Universal remote code for Magnavox tv's
Try this web page
http://www.directutor.com/content/philips-sru210327-universal-remote-control-codes-tv-vcr-set-top-box#codefinder
Ph601s universal philips remote it controls 6 devices tv vcr dvd cbl sat cd
I have a sharp a philips dvd a hitachi vcr apinoneer sound system
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
