How to connect the wireless printer to the computer
SOURCE: pixma mp600r scanning setup
Try turning off the windows firewall.
If that works, then add the Canon scanner app to the list of applications that are allowed through the firewall, then turn the firewall back on again.
SOURCE: All in One Scanner/Printer problems
Go to this link and type "cannot communicate with scanner" in the search box. Click Search. Then select the "ERROR: Cannot communicate with scanner" link. You will see several things to try to correct your problem. Usually, this error shows up if there is another USB device connected which prevents the computer from "seeing" the scanner, even though it can print without problem. So do try to disconnect any other USB device (except mouse or keyboard) and reboot the system.
SOURCE: is a canon Pixma MP160 a wireless printer
Per the information found here, it is not a wireless printer.
If you purchase a wireless print server (similar to a wireless router), you can connect just about any USB printer to it (which would be practically the same as having a wireless printer).
Some wireless print servers that support USB have a maximum of 2 USB ports and 4 or 5 network ports.
The only problem is the additional effort it takes to configure everything to work properly.
Good Luck!
Testimonial: "Thank You, I could not find an answer, and was told many different things. Now I know what to do. Thanks!"
SOURCE: Cannot coonect SCANNER (HP Officejet 6500 wireless) to my Windows
I have seen alot of problem/posts concerning HP AIO's and software issues. Typically some of the functions won't work or not recognized by solution center. Try a complete uninstall of all associated printer software, run registry cleaner if you have it, restart, then try completely uninstalling your Antivirus/firewall software. I have seen that just disabling Antivirus/firewall still causes faulty installations. Now, reinstall your printer software/drivers and connect cables only when told to do so. Some reason the AV/FW software blocks some of the AIO's apps from completely installing.
Hope this works...Good Luck!
SOURCE: Canon MP 640 not recognized by MP Navigator EX 3.0
Your anti virus software is blocking the Canon software. Restore AV default settings.
