Proscan PLT7223G-K 7in Android 4GB Tablet With Keyboard And Case Logo
J
Julian Posted on Mar 07, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
How do I turn my PLT7223G tablet to turn on,it won't turn on when I charge it or hold down the power button
robert
Level 3:
  • Proscan Master 2,548 Answers
  • Posted on Mar 07, 2015
robert
Proscan Master
Level 3:
Answers
2548
Questions
0
Helped
869577
Points
8043
Try holding power button and vol up at same time until screen comes on
Testimonial: "I have no volume buttons only when I turn it on"
Important tips to fix the problem of Kindle Fire won't turn on?
Press and holding down the power button for 20 seconds or more. Then turn the device back on by hitting the power button again. If this doesn't work the first time, you can try holding the button down for 30 seconds or more. Most of the time, this will be all you have to do to make the Kindle Fire work again.Oct. 11, 2014
SOLVED: My kindle won't turn on. Is it the battery? - Kindle ...
How to Fix a Kindle Fire That Won't Turn On - Lifewire
www.lifewire.com > kindle-fire-wont-turn-on-or-charg...
May 26, 2020 - Perform a soft reset. A soft reset resolves many common issues without affecting any data on the device. Press and hold the Power button for 40 seconds, then release. The charge indicator light should turn on after several seconds, and then the Kindle Fire should reboot.
Amazon Fire Won't Start - Technipages
www.technipages.com > amazon-fire-wont-start
Fix an Amazon Fire that Won't Start. Hold Power Button. Ensure that you are holding down the "Power" button for at least 5 seconds to power it on normally. Charge Using AC Adapter. Ensure that the Amazon Fire has a charged battery. Hold "Volume Down" While Powering On. Restore Latest Software.
VIDEOS
https://www.google.com/search?q=Kindle+Fire+won%27t+turn+on
I have a samsung galaxy tab E that won’t recognize its charging adapter or cable. I ordered a new factory specific charger and am still having the same problem.
Hi unplug charger hold down POWER BUTTON FOR 30 SECONDS
KEEP HOLDING BUTTON DOWN PLUG IN CHARGER AND HOLD POWER BUTTON DOWN FOR ANOTHER 30 SECONDS.. cheers
2answers
I pad fully charged cant slide to unlock?
Hi Lynn, The link below is a YouTube video showing how to fix your phone/tablet, Also there's video's down the right side of the link that may help as well....CHEERS..
https://www.youtube.com/watch?v=0PAB6khykWE
How To fix any Android Phone Tablet that won turn on
PLT7223G power pin broken
Try charging it with the USB cable from the computer. It could be your charger pin is faulty. This happens from frequent in and out charging. The pins on the charger tip get worn out. If it charges with the USB cable then get a new charger.Charging from the computer is slower but it works.
3helpful
2answers
How do I reset my wifes proscan PLT7223G to factory specks
Turn off the unit, there is a small pinhole button located between the usb and power connections, not the one labeled reset. Hold this down with a paper clip and hold the power button until the unit comes on, it should show the android guy with an exclamation, hold the button and power again and it will come up with a menu, use the pin hole button to move down the list and the power button to select.
1helpful
My textbook 7p won't turn on
This tablet does t reset with the power button unlike other Android devices. When you hold down the on/off switch, it only drains the battery. If you see the color indicator still charging, allow a full charge.Then, only stay put and pulse the button for a moment quick and let it rest few seconds to try again and again. Only when u see a light coming out of the screen, and I recommend you do this with the power cord on, you hold the power switch down until the rebooting is iniciated. Let go til it is finish and see where the problem is. More likely, like mine, the Settings stop working and needs tune up for the CPU. Never leave an application running when closing your system. With or without internet connection.
My Nextbook 7 won't turn on
Every tablet has a button sequence, the reason being for a fresh restart. Either you unplugged it before full recharge, or didn't use proper charging adapter or cable.
There is a solution to avoiding this but first get tablet started by:
Hold power button and volume up button for eight seconds, release and hold power button again, tablet should turn on.
If not, do the opposite hold power button, volume down for eight seconds, then power button. You need to do this with proper adapter and charger you tablet came with plugged in. You may also need to do this more than once.
Once your tablet has started up, the way to avoid this is to swipe right on screen until you see settings app, should be round looking similar to a sprocket, or clock gear.
Open settings / display / sleep. I set mine for 30 mins.
Now you no longer need to power off you tablet manually, thus skipping the button sequence process.After unplugging from charge adapter you will still need to press power button to start.
Hope this helps I have yet to have this problem again, and remember to always let your tablet fully charge before disconnecting.
Top Proscan Tablets & eReaders Experts
 Mikey
Mikey
Ngoro
ADMIN Andrew
ADMIN Andrew
Are you a Proscan Tablet and eReader Expert? Answer questions, earn points and help others
