Question about Brother DCP-330C All-In-One InkJet Printer
Http://www.fixya.com/support/p507450-brother_dcp_330c_all_in_one_inkjet (unable to clean 50)( unable to print 50) codes appears and stops all further prompts
    New Friend:
  • 28 Answers
Ctnozil may be correct, but hete is a link to The Brother webpage, Faqs and Troubleshooting :
http://support.brother.com/g/b/faqend.aspx?c=us&lang=en&prod=dcp330c_all&ftype3=1964&faqid=faq00000565_013
If you want to go to http://support.brother.com - put in your model and on the next page on the left was the FAQs link to the above - Good Luck Boots66
Posted on Mar 12, 2015
    Champion:
  • Brother Expert
  • 270 Answers
Replace the maintenance unit .
Posted on Mar 07, 2015
6ya staff
SOURCE:
My printer brother dcp-330c have "unable to clean 46" problem.. the answer in your website doesn't help as i was unable to enter the maintenance mode from the instruction.. my printer does not...
I developed the same problem "unable to clean 46" on my brother dcp -330c printer.. after taking to a maintenance guy... he told me to remove my ink absorption pads and wash them out with water and leave to dry then once dry replace back in..
Apr 14, 2011 | Brother DCP-330C All-In-One InkJet Printer
I am getting error Unable to Clean 50 My brother printer model is DCP -330C..Anyone got any idea??Plz help
I'm afraid there is no simple solution to this problem.
Error codes 50 and 51 refer to problems with the purging mechanism - some of the whirring and clicking noises you hear when the machine self cleans or starts up are it purging ink from the print head. Through some very clever mechanics, the machine uses the paper feed motor (running in the opposite direction to normal) to perform purging.
Possible causes listed in the Brother Service Manual for this error code range from "simple" things like a misaligned cam, to complex problems with the main control board. However, whatever it is, dismantling these machines isn't staright forward and parts are very diffciult to obtain and very, very expensive, so much so that 99 times out of a 100, it isn't cost effective to repair.
You could approach a Brother service agent, but it's highly probably that they will charge you more than buying an equivalent brand new machine.
Sorry.
Apr 02, 2011 | Brother DCP-330C All-In-One InkJet Printer
Want the reset info for g46 unable to clean .dcp-330c .and would it be better to clean the waste pad as well?cheers.
Cleaning won't help as it's a counter that sets the error. It's a sealed plastic box that needs to be replaced and then reset thru service mode.Brother only gives the reset codes to authorized service centers.
Nov 27, 2009 | Brother DCP-330C All-In-One InkJet Printer
Unable to print 50
simple driver configuration problem linux is (the Cups printing system) is pretty universal just get your settings right or even cr even surrogate settings it should work
Nov 27, 2008 | Brother MFC-440CN InkJet Printer
Brother Print Unable 50 Error
No ;-)
The encoder strip switched off the ph and has to be set into place again.
see here how to fix it:
http://www.fixya.com/support/t211210-brother_mfc845cw
(enlarge the browser window to see pics somewhat better)
An advice:
when you have set the encoder strip in pos. again stick some scotch tape on the top of the ph cover where the strip runs thru to prevend the slipping off again on next paper jam ;-)
Mar 29, 2008 | Brother DCP 130C All-In-One InkJet Printer
Brother DCP 330C
This COULD BE that there is some paper stuck in the dcp. Open cover and try to see if there is some paper left in the machine. I ve noticed, that -seeing from behind!- on the right side paperpieces are stuck and disturb the disk (foil) which give the printer info what to do. Open cover and try to look into the edges (seeing from the front: its the left side -where the modell name is printed) In some cases this means that the purgecamshaft is defective.
Aug 17, 2007 | Brother DCP-330C All-In-One InkJet Printer
Brother DCP-330C All-In-One InkJet Printer Logo
121 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Jim Keysor
