Computers & Internet Logo
A
Anonymous Posted on Mar 07, 2015
Would like to see a diagram of lymph nodes of the lung, such as right lower and right lower posterior
Anishka Sharma
Level 1:
Habit-Forming:
New Friend:
  • Contributor 6 Answers
  • Posted on Mar 01, 2018
Anishka Sharma
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
6
Questions
Helped
2799
Points
32
In humans, the lungs are divided between the left lung and the right lung and further, they are segregated into lobes. The left lung in humans is smaller than the right lung since the right lung of the person has three lobes and his left lung has two.
Lung Transplant Procedure
Edward
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Mar 07, 2015
Edward
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
10011
Points
83
What does it mean to have inhomogenously enhancing lymph nodes adjacent to the aortic arch measuring 2 cm. The patient has colorectal cancer with metases in the liver and the lungs
It means they're very sick and should in all likelihood be in the hospital under a doctors care who has the training to know what this means.
It means they've got swelling of their lymph nodes near their heart, and their cancer is spreading.
2answers
What does the lymph gland do?
Lymph vessels route lymph fluid through nodes throughout the body. Lymph nodes are small structures that work as filters for harmful substances. They contain immune cells that can help fight infection by attacking and destroying germs that are carried in through the lymph fluid.
There is a thing called "Google"
How do I stop my ankles and feet to swelling after being sun burnt
Hello Anne.
Since this is a Q & A about cars and trucks,,, I will venture off topic..
This is serious and therefore should be evaluated by a physician. When you go to your doctor's appointment, be prepared to discuss the following possibilities. If the ankle swelling started just after the sunburn, it may be due to an inflammatory reaction as the skin tries to heal. A sunburn is a first degree burn but it still causes local inflammation and pain. As the body mounts an inflammatory response, the capillaries in the area dilate and become leaky. This process can cause localized edema and swelling, which usually resolves on its own over time. However, not every sunburn causes this reaction, so if yours is severe, you should see a physician. The reason you get extreme pain when you stand still is because the blood is pooling in your lower legs causing the swelling to increase. It is so painful cause the tissues are ripping apart to create room for the 'blood pooling' or tissue swelling. The most sensitive areas are the shins cause the tissue is tightly attached to the bone. That is why when you sit down or lay down it subsides or goes away. The body is not "upright" causing gravity to pool the blood in your lower legs ankles and feet can also be due to lymphedema. Lymph fluid travels up through vessel and is filtered through the lymph nodes of the body. Any issue with the lymph nodes or vessels in your leg can cause the fluid to pool in lower areas of the leg. If you have ever had lymph nodes in your abdomen, pelvis, or legs removed or irradiated, you should see a doctor very soon. Another possible cause of your problem, is your body retaining too much fluid overall, which can be manifested as swollen ankles and feet. This condition, called pitting edema, can affect people who have problems with their heart, liver, or other body systems. When fluid builds up in the legs, it can also build up in the lungs and other critical organs, so it is important to have this issue evaluated immediately. I strongly recommend that you make an appointment to see your primary care doctor ASAP!!, and he or she can refer you to a specialist if this becomes necessary.
What is a lymph node? is it a swollen gland and could redness come with it on y neck but the swollen is on side of neck.
You have lymph nodes all over your body, including your neck. The lymphatic system is a third part to your circulatory system, and carries a clear fluid, lymph. The lymph nodes are junctions in this system, but are not glands as such.
They can become infected like any other part, and you should visit the doctor who will sort out what part is involved, and what to do.
I have a lymph node on right side of neck i must have it removed im scared in case its cancer
please consult your medical doctor for advise. Lymph nodes are normal organs in the body and form an important function in its physiology.
Refer this article. If you have swelling then there could be other causes.
Swollen Lymph Glands Lymph Nodes Cancer Patient co uk
Once again please note fixya is not a site for seeking medical advise. You should consult a medical practitioner.
Swollen lymph on the left side
If you mean that you have a swollen lymph node, then you should see your doctor if it does not clear up within a couple of days. Swollen lymph can indicate an infection somewhere else in the body and often easily rectified.
However, a swelling in there region of the lymph nodes can indicate more serious issues and so a vist to the doctor is highly recommend if it goes on for more than just few days or becomes very painful.
IF you are referring to swollen lymph in a blood pressure monitor, please forward more details
good luck
Neck lymph nodes diagram
Through the Eustachian Tube?
Don't know
Do know that is NOT a Laptop PC question, and you are on the wrong website for such a question.
Good luck in your endeavor to find the answer, and godspeed to becoming a physician.
Live long and prosper
Regards,
joecoolvette
Grand Canyon Tech
Grand Canyon Tech
