SOURCE: SanDisk, 2 GB Sansa mp3 player won't charge
I was having the same problem with my Sansa e250. My wife has the e200, and we didn't have any problems with that. I saw that someone on here suggested to lock the mp3 player with the tiny metal switch on top, so I did, and the battery charging icon on the bottom of the screen came on and stayed on, and the mp3 player worked. thanks!
Because of this I would suggest checking to see if it's locked or unlocked and then change it to charge it.
You MAY have a power glich. In which case, hold the power/menu botton down for 20 seconds or more, then connect it to the computer.It's best if you use a USB input that's NOT part of a Multi-USB base, as those DO cause power gliches.
SOURCE: I can't seem to turn on my Samsung YP-T7J MP3 Player
on the bottom of the mp3 player there is a very little button that u need a needle to push its the reset button sometimes these mp3 freeze and u must push the reset button it u dont loose any music or saved files anything like that it just basically turns the mp3 player off for u so that u can then turn it on using the play and pause button on the side of the mp3 player if this doesnt work the i guess tuff nooges
SOURCE: WHARFENDALE SLM01 2 GB Mp3- why are earphones so small?
a solution would be to buy a 3.5 to 2.5mm converter. Then you can use your decent earphones with the wharfedale
SOURCE: i Have a Hip street digital mp3 player 2 GB and it wont charge
try this.. charge your mp3 player but put it on
