I forgot my password to get me activated on my ipad I was able to change my apple password on my laptop but still my ipad wont accept it what
SOURCE: I updated my exchange password on my laptop today
I've seen this happen with mobile devices sometimes, do you have any special characters? Make sure you're putting each character of your password in correctly. If you're certain that you are, log back in to your laptop and change your Exchange password to something simple like Password123. Wait about 20 minutes (it can take time for the password change to take effect across the domain) and try logging in with this new password. If it works, it was the password. If not, the issue may be on the iPad.
If that's the case, try removing the account from your iPad and re-adding your Exchange account. Hope this helps.
SOURCE: ipad wont connect to internet
Go to settings and then wifi if it is off switch it on and then select your wifi router and enter your password
SOURCE: My Ipdad is disabled
You should log onto Itunes, and when you go on Itunes you connect it. After that you just have to restore your ipad and go through the setup again. The only problem is that all the things you have saved on the Ipad will be erased.
SOURCE: Ipad disabled b/c son forgot his password...help us get in?
If your son cannot remember the passcode, you will need to restore your iPad using the computer you last synced your iPad with. Using the last computer you synced with allows you to reset your passcode and re-sync all your data, apps, etc.
To begin the process, connect the iPad to your computer using the USB cable or lightning cable. Open iTunes and select the restore option.
If you restore on another computer, you can still unlock the device and remove the passcode, but your data and apps will be wiped.
Hope that helps!
SOURCE: how to set up password on my new ipad mini
The following can be done on ipad with iOS 8:
1. Press the home button( the round button on the front side of your ipad), to go to the home screen.
2. Find the Settings icon ( looks like gray clockwork gears) and tap on it to launch the Settings app.
3. After settings app is started try to find on the left side of the screen Passcode ( has a red lock icon near the text) and tap on it
4. In the passcode setting screen you can choose the type of passcode with the Simple passcode setting switched on or off ( simple means a 4 digit number, not simple means any character combination
5. By taping on Turn passcode on you can enter your passcode. Be carefull not to forget your passcode, otherwise you will not be able to use your ipad later.
