Spark Plugs BR4HS  Plug 10/BX #3322 Logo
A
Ally Gray Posted on Mar 06, 2015
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Need brief description on how to fit these to my Kawasaki VN 900
Derrick Schultz
Level 3:
Top Expert:
  • Ngk Master 11,405 Answers
  • Posted on Jan 29, 2019
Derrick Schultz
Ngk Master
Level 3:
Top Expert:
Answers
11405
Questions
0
Helped
2331010
Points
23972
I take help from online websites that have this service like helping in repair some like reliable-store have instant help.. others are a bit slow which I don't prefer... rest is up to u
U can also get free manuals
Kawasaki vn 900 custom new battery fitted lights come on wont turn over
Please forgive me if this is a strange question, but did you charge the new battery?
Starter solenoid kawasaki vulcan
my kawasaki vn 900 is making a chattering sound when I try starting it
2answers
IS MY 2008 KAWASAKI 900 A CUSTOM OR A CLASSIC I UNDER STAND I NEED THAT INFO SO I CAN ORDER A WINDSHEILD . MY VN # IS JKAVN2B108A033752 THANKS FOR INFO
The VIN decoder info is below. Since the Vin shows it to be a VN900B, the bike is the "Classic" model. Please rate my answer. Thanks. tombones49_142.gif
1helpful
07 Kawasaki Vulcan 900 on start up the solenoid stays engaged & starter motor stays running. What could cause this?
Bad switch,Bad relay,bad solenoid the solenoid may need cleaning.
For troubleshooting remove the positive wire from the starter.
That is the biggest one. on the starter.
Now place a load on the wire say a headlight or 12 volt fan
1helpful
Battery keeps dying in my Kawasaki 900
possible reg/rec issue or the stator....if you have a multi meter you can check the stator by unplugging and hooking up to the stator (component side), set multi meter to volts a/c and connect each plug for voltage. then do a residence test on the stator.
reg/rec issue, make sure you have proper ground, do a diode test to make sure that it is d/c and not a/c
2helpful
Noise at low rpms after heavy rain sounds like a siren but go's away at cruising speed 2008 valcun 900
It's your drive belt if this is a 900 Vulcan... They make noise when they are wet... Good Riding!
Top Ngk Vehicle Parts & Accessories Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Ngk Vehicle Part and Accessory Expert? Answer questions, earn points and help others
