Ignore the instructions I found its not as easy as they say first you need to sync the digital and analog to do this press all four buttons at once and hold for 3 secs tho sets the digital clock to 12 Now press mode till you see h-s hold reset till h-s flashes hold the start button in the analog will start moving its slow so be patient set analogue to 12 exactly ignore the minutes that have passed press preset the minute hand will automatically adjust once done press mode go to the main watch screen hold preset use mode to select hours minutes date year month etc and start to change the values keep it on 12 not 24 hour clock set the clock and press preset the analog will now automatically adjust to the time once done you can change to 24 hr mode if you wish
SOURCE: I need a user manual for a Pasnew watch Model
First off, press the "mode" button for 3 seconds.
Secondly, after the watch enters the "Time Editting Mode", press the "mode" button for 1 second (Clearly to say, it's recommended that you should release immediately right after you press it).
Lastly, press the "start" button to navigate through hour, minute and second numbers. In order to change those values, you need to press "alarm" button several times. Hence, the values to be set increase.
