Screen shows wrong URL Safari won't load.
By the way you are stating your issue, I am not sure if you are referring to Safari loading to an incorrect URL and that it is not launching. So to make sure I cover all bases I will provide advice for both.
If Safari is loading to a URL when you first launch it, assuming you are referring to the URL of the Home page you need to see, all you have to do there is launch Safari, click on the Safari name in the menu, select Preferences.
* Then under General> "Home page:", make sure the home URL is set to the web address you want to see as your home page.
If Safari is not launching on the other hand, here is what you need to do in order to resolve that issue:
font.f1 {font: 12.0px Helvetica}
• From your desktop,
•Click anywhere on a blank space on your desktop. Now you should see Finder listed near the Apple menu icon.
• From the Finder menu, click on Go, then Home from the
drop-down menu. This will take you to your Home folder.
• Locate and open the Library folder
• Within Library folder look for the Preferences folder and open it.
• Locate and remove to the Trash, these files:
com.apple.Safari.com
com.apple.Safari.RSS.com.
Now click the back button in the Finder window to go back to the Library view.
* Locate and remove to the Trash, the folder entitled "Caches"
* Once you have done that, close all windows and other applications, click on the Apple menu icon and select from the drop down menu Logout<username>.
This will take you to the main login window
* simply log back in to the same user account.
Don't attempt to launch Safari, just yet. Instead run this last procedure to repair file/folder permission on your Mac OS X volume (including Safari)
font.f1 {font: 13.0px Myriad Pro}
-RUN DISK UTILITY FIRST-
Go to Finder Menu bar
• Click Go > Utilities > Disk Utility and open up Disk Utility app.
• Click on Macintosh HD volume (or on the name you have changed
this volume to.)
• Select "Repair Disk Permissions"
**Let Disk Utilities run this repair permissions until completion
- This is not often a necessary step, but in the many of the hands-on software and Mac OS X troubleshooting
* Once Disk Utility is complete and there are no errors in red in the completion summary (if there are errors listed in red, re-run DU to see if those error will clear- if they don't reply back to this post right away and let me know what the exact error message is), quit Disk Utility.
• Now relaunch
Safari and let's see if it launches ok for you.
If this is still not resolving the issue you are having with Safari, just let me know.
Regards,
-Mactechtrainer
