SOURCE: Trio stealth-10 touchpad only works half way
www.samsung.com/us/support
https://support.google.com/android/?hl=en
SOURCE: I have a trio Stealth-10 tablet and when i turn it
you have malware or virus best suggestion is to reset it to factory default assuming it has an android operting system
SOURCE: My trio stealth 8 keeps resetting it self to
Try doing a factory reset. It can be done from the setting menu usually, or via a special button combination. Google will help you if you google your model number and 'factory reset'
SOURCE: My trio stealth-10 tablet is frozen
Press the volume up and power button for about 10-15 seconds to reboot.
FIXED ! Well almost... This problem is happening with the 'old' Android devices; Software if changing every day and most of the updates are barely tested on all devices and Android versions. The spyware, malaware, adware, are then becoming day after day more aggresive and sophisticated. So, the clean solution if format/clean/reinstall Original software, no updates.
Another helpful hint is clean all software cache, saved data, for each application , one by one, and then...
install Avast antivirus free and block behaviours, "APP LOCKING" option, at least of "Play Store" and "Downloads".
You won't see anymore the annoying message, and device will work like a charm.
Thank you, Bye. FIXED !
