Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
A
Anonymous Posted on Mar 05, 2015
The CD will not open. The parameter is incorrect. How do I fix this problem?
Edward
Level 1:
New Friend:
  • Contributor 33 Answers
  • Posted on Mar 07, 2015
Edward
Contributor
Level 1:
New Friend:
Answers
33
Questions
0
Helped
10024
Points
83
Assuming the cd is in the drive. it may not Auto run or the cd may be damaged First see if the cd will open with file manager
If so look for a program file with an .exe extension Click on this to run it, If you cannot access the dc with file manger try cleaning the cd with toothpaste water and a soft cloth rub toothpaste diagonally to the center with your finger, You may also try boot from the cd with the CD in the drive as the machine starts press F10 . hope this helps the ed
Denis Stephenson
Level 1:
New Friend:
  • Contributor 26 Answers
  • Posted on Mar 06, 2015
Denis Stephenson
Contributor
Level 1:
New Friend:
Answers
26
Questions
0
Helped
1390
Points
34
Probably a bad cd player they are cheap and easy to replace.
phillip
Level 1:
New Friend:
Problem Solver:
  • Contributor 13 Answers
phillip
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
13
Questions
Helped
13326
Points
25
On all PC's there is a small hole near the on/off button in the CD where you can insert a pin to open the CD. This will generally force the CD to open.
Error parameter incorrect
Toast I'm afraid by the sounds of it. Your only hope is a data recovery expert if you really need the data, but they are not cheap
CANNOT OPEN QUICKBOOKS
According to intuit Error : 80070057 PARAMETER INCORRECT is most common problem. for knowing its cause and step wise solution follow Error 80070057 the parameter is incorrect or You do not have sufficient... and if need any guidance while understanding any technical prospect follow Intuit Help by Intuit Certified Technician .
1helpful
The parameter is incorrect how do I fix it ?
delete the shortcut and find the exe file and right click/ hold and drag to the desktop
or right click on deskto/new /shortcut browse to file and select
When i click on my game to play the parameter is incorrect pops up
Do you need or you don't need the CD or the DVD to play that particular game? The problem may be due to changing of your CD/DVD ROM after you have installed the OS.
2helpful
Parameter incorrect
i can't open mail in YM,coz parameter is incorrect and i can't open link message to reply in my microsoft outlook 2007 too
Turbotax 2008
Hello There, I found this in their FAQ Guide. Hope this resolves your problems, I know it is a bit of a read. Good Luck!!
What is happening?
Double-clicking on a backup, portable company file, or a file with an extension other than .qbw, the following error occurs:
An error occurred when QuickBooks tried to create, open, or use the company file. Please try again. If the problem persists, contact Intuit Technical Support and provide them with the following error codes: (-6150,-1006).
Or, if you attempt to double-click the data file without QuickBooks open, the following error occurs:
There was an unexpected error reported while trying to run QuickBooks with company file "path location". Error code 80070057.
Note: More than one error message that includes the error code 80070057 exists. If this is not the exact wording of your error message please refer to one of these other documents:
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, QBW, NT, or TLG file from a Google Search Timeline
Error: 80070057 parameter is incorrect" when clicking on a QBB, QBM, NT, or TLG file from a Google Search Timeline
Error: 80070057, the parameter is incorrect. There was an unexpected error reported while trying to run QuickBooks with company file [path and name]
Error: 80070057 the parameter is incorrect" and "You do not have sufficient permissions to delete files...
If your Error 80070057 is different than the ones displayed, perform a new Search.
Why is this happening:
QuickBooks cannot read the company file because the QuickBooks file extension was changed or is the wrong type (.qbm, .qbb, .qbx).
This error can also occur during conversion or creation of a backup or portable company file if QuickBooks detects data damage in the company file.
This error may possibly occur if the QuickBooks installation is damaged.
This error can also be caused by attempting to open the portable company file (.qbm) without having QuickBooks open.
How to fix the problem:
Verify that the file extension displays company name.qbw and not a shortcut.
Copy the company file, change the extension to .qbm, .qbb, or .qbx, and follow the appropriate steps to open a portable file, backup, or accountant's review.
If the error occurs during the conversion or creation of a backup or portable company file, run the Verify utility to check the file for data damage. If it finds damage, run the Rebuild utility.
Repair the QuickBooks installation.
Uninstall, and then reinstall QuickBooks.
Reinstalled Windows xp professional to my acer aspire 3610
1.change another Installation CD of Windows XP service pack 2 or install Windows Vista.
2. if any track of your CD is corrupted, then this type of error comes.
3. sometime if your hard is not formated correctly, then also some fatal error comes.
4. when formating always do full format, donot do quick format.
1helpful
Unsupported media/incorrect parameters
It is a poor quality player. It probably isn't built-to-last and as I can see, has problems. Try going into My Computer and right click it, Format it and select all the songs and drag onto the player and see what happens.
1helpful
Cannot open or copy - parameter is incorrect?
Are you using the same card reader for both memory cards? It's probably just your card reader. I had this problem before and it turned out to be my usb cable for my psp.
2answers
download a software called mini tone and it will read it
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
