Dyson Ball DC24 Bagless Upright Vacuum Logo
A
Anonymous Posted on Mar 05, 2015
How do I get the brush to spin on a Dyson DC 24. I have thoroughly cleaned everything and pressed the reset button.
Thatvacguy.com
Level 3:
  • Dyson Master 1,619 Answers
  • Posted on Mar 05, 2015
Thatvacguy.com
Dyson Master
Level 3:
Answers
1619
Questions
0
Helped
604984
Points
3345
It could be the brush bar motor or wiring problem. It could also be the brush bar switch or the. Switch that activates when you pull the handle back.
ptpumpman
Level 3:
Fixya-Fanatic:
Visited the website for 90 consecutive days.
  • Master 408 Answers
ptpumpman
Master
Level 3:
Fixya-Fanatic:
Answers
408
Questions
0
Helped
76928
Points
1267
Hi , if i am correct the brush bar is driven by a small electric motor inside the brush bar. It sounds as if the motor has gone or the small printed circuit board has a fault. You will have to get it checked.
Dc dyson 24 free repair maule
About 1,100 results (0.84 seconds) Search Results
    Dyson DC24 - Resetting the brush bar (Official Dyson video ...
    ? 1:55
    https://www.youtube.com/watch?v=akGLQ7UbctY
    Sep 29, 2011 - Uploaded by AskDyson
    DC24's brush bar is engineered to shut off for protection if something jams i. ... How to clear and reset the brush bar of yourDyson DC24 upright vacuum cleaner ... Dyson DC24: How toRepair a Loose and Clunky Ball. ... Dyson Ball DC 25 not locking beater bar brush in place while upright - Duration: 17:09 ...
    How to fix your Dyson Vacuum Cleaner when it loses ...
    ? 7:45
    https://www.youtube.com/watch?v=0vd3ldLXgI4
    Apr 16, 2013 - Uploaded by Chuck Fresh
    How to clean the two filters in your Dyson Ball or Animal Vacuum... troubleshooting computer problems, pc helpline, free pc repair... How to take apart Dyson DC 17 to Clean and Service - Duration: 14:33. n4ktz 178,332 views ... Dyson DC24 - Resetting the brush bar (Official Dyson video) - Duration: 1:55.
    [PDF]Dyson DC24 Manualhttps://www.dyson.co.uk/.../Dyson/.../Manuals/DC24_Manual.pdfDysonNote your serial number for future reference. After registering for your 5 year guarantee, your Dyson vacuum cleaner will be covered for parts and labour for.Dyson DC24 Manual - ManualOwl.comhttps://www.manualowl.com/p/Dyson/DC24/Manual/112339Manuals and user guide free PDF downloads for Dyson DC24. ... I Have A Dyson Dc17, Is There A Fuse Or Reset Button On The Vacuum Motor ... Complete Dyson customer service phone numbers and contact information at ContactHelp.com.Dyson DC24 Multi Floor Instruction pack - Part 914529-01 ...https://www.dyson.com/parts/u/user.../dc24userguide.aspx?...DC2...DysonDyson DC24 Multi Floor: Instruction pack - 914529-01.Buy genuine parts and accessories direct from Dyson.DYSON DC24 USER MANUAL Pdf Download. - ManualsLibwww.manualslib.com > ... > Vacuum Cleaner > Ball DC24Page 2: General Safety Precautions. Do not use with damaged cable or plug. If the supply cable is damaged, it must be replaced by Dyson Ltd, our service agent ...
Dyson dc 24 brush works intermittently
Broken wires in the side of the machine
1helpful
Dyson DC 24 brushbar motor stops working , every so often , I press the reset button then it works for a while and stops again till I press reset again.
Hi there, it's Jack at Dyson.
DC24 is equipped with a safety device which shuts off the brush bar if something jams it - for example, a shoelace or a rug fringe. From what you've described, it sounds like there may be something in the cleaner head which is jamming the brush bar. It's also important to remove any threads or hair from around the brush bar regularly. Please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc24/dc24-multi-floor/my-machine-is-not-working/my-brushbar-is-not-rotating/stabiliser-check
You may also find the video below useful. Make sure that before you test the machine, you've reclined it into the vacuuming position, because the brush bar will never rotate when the machine is standing upright.
I'm confident this will resolve the issue, but if you'd like any further assistance, please give our Helpline a call on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Can't release brush head on dyson dc24
I'm sorry to hear you're having difficulties with your DC24. The red button you're referring to is the brushbar motor reset button; the catch to release the brushbar is on the underside of the cleaner head.
To clean any threads or hair from the brushbar, please follow the steps shown in the video below.
I hope this helps - if you'd like any further assistance or advice, please call us free on 0800 298 0298 (UK), or 1-866-693-9766 (US).
Best wishes,
Jack
33helpful
2answers
Brush stopped spinning
If you've had the brush out to clean it you need to re-set the trip switch which is a red button at the right side of the brush simply press it in till it clicks.
7helpful
The brush bar wont spin on my dyson dc 25... i
Hi its Darran at Dyson.
Simply switch the machine off and stand it upright. Press the brush bar on/off switch once and then turn the machine back on.
When you release the machine into the vacuuming position, the brush bar should start to turn again.
If you still having problems, please contact our Helpline on 0800 298 0298 (UK) or 1866MYDYSON (US).
Kind regards
Darran
Dyson Customer Service
66helpful
3answers
Dyson DC 24 pick up head wont spin
- Look for the reset button on the side of the brushbar housing - there should be a red sticker and a red button. Push it once. It's
not gonna stay depressed, it's gonna pop right out - that's normal.
- Step on the red pedal on the back
- Turn the machine on with the red power button
- Press the gray button next to the red power button - this is the ON/OFF switch for the brushbar - if it doesn't spin, press and hold the gray button down for 10 seconds
- If it still isn't spinning, remove the brushbar and make sure nothing is blocking it and withholding it from spinning
- For further troubleshooting assistance call the Dyson helpline, they know what they're doing
Top Dyson Vacuums Experts
AskDyson
AskDyson
Sean Wright
Sean Wright
xxxxxx xxx
Are you a Dyson Vacuum Expert? Answer questions, earn points and help others
