IT IS TWO PHASE OR THREE PHASE
It requires two hot wires measuring 240 volts across them and 120 volts from either of them to the neutral connection. Some people refer to the two 'hots' as 'two-phase' and some refer to it as 'single-phase'. At any rate, you do NOT have three phase requirements with that dryer.
Most of the dryers have a 120volt motor which is why you need two hots and a neutral. To complicate matters, recent changes to the code now require 4 wires on newly constructed structures. Two hots, a neutral AND a bare ground wire.
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
