The convergence amps have most likely failed. That unit takes two STK392-110 (Sanyo) amps. For more reliability I'd have them changed using an STK392-150. They have a greater amperage and higher heat tolerance.
It's clearly a job that you want a qualified shop to do.. Call around and get some off-the-cuff estimates on what they charge to change out the convergence amps and tell them that you would prefer they use the 150's instead of the 110's.. They'll probably wonder how qualified you are. :)
Bill
Test test
First are you sure the blue tube is ok,-make sure blue tubedoes not have burnt in image,and I advise you to REPLACE stk-392-110s with STK-392-180s, they are better then the 150s
the green light on the screen is fading away and moving away from the other colors
Our PT-51HX41 has a red shadow that we cannot fix with the convergence function. Does this mean we need a new red tube?
