Question about Singer Sewing Machines
How do relase the Reverse Lever for Singer 756 when using the flex stitch mode
My sewing machine sews in a backwards way. The regular stitches are fine. The reverse lever is lowered some and it shouldn't be. What causes this I don't know.. This is a good sewing machine .
    Guru:
  • 96 Answers
This man is your best source for getting your machine back on track.
http://www.tandtrepair.com/700TS.html
Posted on Mar 05, 2015
6ya staff
SOURCE:
SINGER TOUCH N SEW 771
Use the wheel at side of machine and gently push back and forth it should release reverse lever
Mar 04, 2015 | Singer Sewing Machines
Singer Simple 3116 only sews backward.Looking for answer I saw earlier that involved several steps including buttonholer
You are stuck in buttonhole. The selector knob does not spin round and around. It is moved from Stitch 1 to stitch 14 and back. Try selecting buttonhole and then running the knob in the other direction to straight stitch. If that does not work, (1) drop the lever that senses the button hole attachment, (2) sew a few stitches backward, (3) push the button hole lever rearward, once, hard, (4) rotate the stitch selector to straight stitch.
Jan 09, 2015 | Singer Sewing Machines
My sewing machine will only sew in reverse
The stitch length lever on some machines will back stitch when the lever is in the uppermost position. Bring the lever down to an appropriate stitch length and your machine should stitch forward.
Oct 11, 2014 | Singer 3116 Simple
Is there a button on this 807 machine bernina which you can press for it to stitch backwards like on the singer machine 507 as its saves time on tiring ends up at the beginning and end of sewing thank...
The stitch length control is moved upwards, beyond the 'zero' position to make it sew backwards. To demonstrate, with the machine off, adjust the stitch length to '2' using the knob on the stitch-length lever. Now push the lever upwards until it stops - it will go past the zero position and this is now in reverse mode.
May 15, 2011 | Bernina Activa 130
Singer Model 6212c only sews in reverse... Just brought this machine home today. Ha Ha, it only sews in reverse mode.
there's probably nothing wrong with your machine.
check and see if your stitch length setting is set to Stretch instead of somewhere between 2 and 3.
If it's in the stretch zone (below 0), it can sometimes sew backwards unexpectedly depending on what stitch you have selected.
make sure you have selected a straight stitch, and then select the highest stitch width and a stitch length of somewhere between 2 and 3.
it will most likely work fine.
Apr 02, 2010 | Sewing Machines
Won't sew backwards when freestle sewing
If you are free-motion stitching, then you should be using a darning foot and have the feed dogs lowered. If so, then you are feeding the fabric, not the machine and the reverse lever/button will have no effect.
Jul 10, 2009 | Singer Sewing Machines
Even feed foot not feeding evenly
try going to http://www.singerco.com/support/presser_help.html
there is several help pages there, if they don't help I don't know whom can... LOL
actually singer has pretty good cust support and answer questions rapidly.
(after all they want us to keep buying their products!)
I hope this helps!
Good Luck and Happy sewing!
Jan 24, 2009 | Singer 7462 Mechanical Sewing Machine
Sewing Machines Logo
79 people viewed this question
Top Singer Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
tsalagi152
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
