if you have lost the key -- then look on the face of the lock cylinder and see if there are letters and numbers on it,, ( key code ) -- take this keycode to your local locksmith and see if they could make the key. if the code is not there then take the safe down to your local locksmith shop and have them pick open the safe. now if the safe is mounted in your house and cannot be removed - then have a locksmith come out and pick open the lock and make new keys for the safe.
well -- if you have lost the key, you can take the serial number of the safe into any loccksmith shop and they will be able to call the safe company and get the key code and cut you a new key.
also -- look on the front of the lock cylinder itself and see if there are any numbers imprinted on the lock and with those numbers the locksmith might also be able to look up the key code and cut the key. the cost of this will be around 15 dollars.
if u notify dealer with vin number they should be able to cut u a new key --if ur key had a electronic chip in it still would need to notify dealer ----if u want to replace ignition switch the switch runs about $130 if electronic more -then u need to add on the price of installing it $65-75 an hour labor cost-- some not many lock- smiths do automotive ignition keys [non electronic ] from vin number
HUBBIE LET SAFE BTTERIES RUN OUT THE LOST BOTH KEYS ( BOTH ON ONE KEY RING??? )
NEED KEYS FOR A ..
NUTOOL SF10 ELECTRONIC DIGITAL SAFE..
HELP NEED PASSPORTS!!!!!!
JOAN
