Question about Mr. Coffee 072179228578 12 Cup Coffee Maker
Clean light won't go out, can't use delay brew feature.
Mr. Coffee, model FTX41...clean light came on, ran vinegar and water through it several times. I still can't use the delay brew feature, I can start the brewing manually but when I push the button for delay brew, it goes to the clean feature. How do I get the delay brew feature to work, bypassing the clean feature?
  • oahu_dave Jul 09, 2009
    Thanks for the solution, it worked the first time! Great service too, the answer came to my e-mail almost immediately.
    Thanks Again,
    David
  • Anonymous Mar 15, 2014
    I recently cleaned it and now the clean light is on again and won't go off. I can't set the delay time.
    President:
  • 1,124 Answers
Try unplugging it for several minuets & see if it clears it..
Posted on Jul 08, 2009
I had the same problem. Just tried carlsbiz's solution and it worked like a charm. Thanks!
Posted on Aug 15, 2009
How do I get a manual for my Mr Coffee BVMCPSTX91-WN? the clean light is on and I don't how how to clean it or how to get the light off
The Mr Coffee web site has the manual on the product page: http://www.mrcoffee.com/coffee-makers/mr.-coffee-optimal-brew-10-cup-thermal-coffeemaker-black/BVMC-PSTX91.html . Click on the Service and Support tab. The direct link to the manual is http://demandware.edgesuite.net/aamb_prd/on/demandware.static/Sites-mr-coffee-Site/Sites-mr-coffee-Library/default/v1426159971356/documents/instruction-manuals/BVMC-PSTX91_43_72624326.PDF . (You'll need Adobe Reader or a similar program to print the manual.)
The Clean light will come on when the Clean button is held. It won't go off until the cleaning cycle is complete; it's completely automated. You need 4 cups (20 oz.) of white vinegar or the Mr. Coffee Cleaner (diluted as directed on the package). Make sure to remove the water filter disk from the unit before cleaning. Pour the vinegar or cleaning solution into the reservoir into the reservoir. Put in a paper coffee filter or the permanent filter into the brew basket and slide it into place. Put the empty decanter in place. Now you should press the Clean button until the Clean light comes on. The unit should slow brew 3 cups of the cleaning solution and then pause for about 30 minutes while the Clean light remains on. It should then brew the remaining solution. After the cycle finishes, the Clean light should go off. Afterwards, you need to empty the decanter and rinse it with clean water. Fill the reservoir with fresh, clean water. Then replace the decanter. The cycle could take an hour.
I hope this helps.
(some brewing systems light the Clean lamp when it's time to clean the unit after lime deposits build up. To my knowledge, most of the Mr. Coffee brewers do not.)
Mar 12, 2015 | Sunbeam MR.COFFE 12CUP P/N/PAUSE,CHROM"
All I need is the manual to my Mr.Coffee Pot how to set the timer to Mr. Coffee GBX23.
First set the clock on the brewer with the unit plugged in. Press and hold the Hour and Minute buttons until the current time is set. Next press the Delay Brew button while using the Hour and Minute buttons to reach the time you want the coffee to begin brewing.
Set up the coffee maker with ground coffee or beans and sufficient water in the reservoir then follow the directions below.
For brewing with fresh ground beans, press and hold the Delay Brew button until it flashes then press Select once. The Grind and Brew light should come on and the Delay Brew light should become steady.
For ground coffee, press and hold the Delay Brew button and then press Select twice. The Brew Only light and the Delay Brew light should both be on and steady.
Most Mr. Coffee product manuals are here: http://www.mrcoffee.com/InstructionManuals.aspx . The direct link to the GBX23 manual is http://www.mrcoffee.com/Manuals/MANUALS/GBX23_43_50118420.PDF .
I hope this helps.
Aug 20, 2011 | Mr. Coffee GBX23
This morning when my wife went to make coffee. The clean light came on. we couldn't get it to shut off. She went through the clean cycle.The light came back on again. What should we do ?? Mr. Coffee...
I know this sounds like a pain but it takes a while to get that silly light to stop.
If you have problems call the 1-800 number below.
Decalcifying your MR. COFFEE® Coffeemaker Minerals (calcium/limestone) found
in water will leave deposits in your coffeemaker and affect its performance. It's
recommended that you regularly remove these deposits using MR. COFFEE® Cleaner
or vinegar. MR. COFFEE® Cleaner is available at many retail stores or by calling the MR.
COFFEE® Consumer Service Department at 1-800-MR COFFEE (1-800-672-6333).
1. Follow package instructions to prepare one batch of MR. COFFEE® Cleaner. Pour the
mixture into the water reservoir. Before decalcifying, remove the water filtration disk
from the machine.
NOTE: 4 cups or 20 fl. oz. of undiluted, white household vinegar may be used as a
substitute for the cleaner.
2. Place an empty MR. COFFEE® 10-12 cup basket-style paper filter
or MR. COFFEE® permanent filter into the filter basket and slide
the brew basket in place.
3. Place the empty decanter back in the unit.
4. Press the CLEAN button until the CLEAN indicator light turns on
(Figure 9). For your convenience the cleaning cycle is automatic.
The entire cycle will take 45-60 minutes to complete.
During the cleaning your coffeemaker will:
a. Slow brew approx. 3 cups of cleaning solution.
b. Pause for 30 minutes (the CLEAN light will remain on to alert
you that the process is active).
c. After 30 minutes, your coffeemaker will brew the remainder of the cleaning
solution.
d. When complete, the CLEAN light will turn off and your coffeemaker will turn off.
5. Discard the cleaning solution and rinse the decanter thoroughly with clean water.
6. Fill the water reservoir with clean, fresh water.
7. Place the empty decanter back on the coffeemaker.
8. Remove and discard the paper filter used during the cleaning cycle. If a Mr. Coffee®
permanent filter was used during cleaning, remove it and rinse it thoroughly before
replacing it in the filter basket.
9. Begin brewing and allow the full brew cycle to complete.
10. Repeat steps 5 through 9 one more time.
Mar 27, 2011 | Microwave Ovens
My Pot wont brew
mcdevito75 here, Your Mr. Coffee may need cleaning, here"s how, Fill the resovoir with white vinegar, cycle thru the machine 3 times, half way thru the 3rd time stop 1/2 way thru and turn off machine for 30 minutes, then recycle. After that rinse your Mr, Coffeee by cycleing thru fresh water each cycle takes another resovoir of fresh water to get rid of the vinegar. If this is not the problem, maybe the pump is shot. Contact Mr. Coffee by phone or online at Mr. Coffee.com or replace the machine.
Jul 09, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
It is stuck on large and does not brew
My keurig did the exact same thing. Stuck on large and wasn't pulling water into coffee maker so it would only dispense a small amt of coffee. I turned it off for about 10 mins. Emptied the reservoir and filled it half way with white vinegar. Ran several cups through and after 2nd brew it ran faster and after the 3rd run with vinegar all the size cup lights came back on. It is working great now. Just empty reservoir with remaining vinegar and rinse. Run a couple cycles of plain water through the coffee maker to rinse out vinegar. I hope this works for you.
Dec 27, 2009 | Keurig B60 Coffee Maker
Mr Coffee stopped brewing
Sounds like there are a couple of problems -
First, are you certain that the coffee basket is clean? If the coffee basket has a valve on the bottom that allows you to remove the carafe to pour a cup of coffee, make sure the valve is clean. Being dirty would cause it to trickle coffee slowly into the carafe, and will hold coffee in the basket too long.
2nd, you may need to flush the water heating system as they can become corroded with precipitated solids from the water.
To do this, mix 1 part vinegar to 2 parts water in the carafe. Pour into the coffee maker and tell it to make coffee. Do this a couple of times, using a fresh mix of vinegar and water each time. Pour the used mixture down the drain.
When you feel it is clean, follow it up with a fresh pot of water. Then wash and rinse the carafe.
The coffee maker is now ready for it's next use.
Jan 30, 2009 | Mr. Coffee 072179228578 12 Cup Coffee...
Mr. Coffee won't brew - Mod. #ECX30118
IF YOUR HAVING ISSUES WITH THE ACTUAL BREW OR CLEANING CYCLE AND IT WILL NOT WORK, THERE IS NO TROUBLE SHOOTING THAT CAN BE DONE. MR COFFEE CARRIES A YEAR WARRANTY SO YOU SHOULD CALL THEM TO HAVE THEM REPLACE THE UNIT.
Jan 14, 2009 | Mr. Coffee FTX24 12-Cup Coffee Maker
Cleaning light will not quit blinking after cleaning
The same thing happened to our Mr. Coffee this week! I followed the instructions about running vinegar through, then rinsing several times with water. However, the light would not stop blinking. We did by-pass the light by setting the timer for delayed brewing and it worked. However, that blinking light came on again. Then, my husband tired the vinegar wash again but instead of doing it one time, he ran the same vinegar through 6 times until the light went out! Then he proceeded with the water rinse. Our Mr. Coffee is working again!
Nov 16, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
Slow brew time / water disappears?
I have this problem with a 4 cup model. 4 cups in, 2 cups out. I cleaned it twice with vinegar (with a filter in place). The first time didn't seem to help, but the second time I got about 2.5 cups out, along with a bunch of old grounds that I think had been sucked into the pump. Ran water through it twice, and now it gets to about 3 cups.
I think the problem is just that the pump is clogged with grounds. If vinegar makes yours worse my guess is that a big piece got dislodged and is now blocking the tube. More vinegar might help.
May 20, 2008 | Mr. Coffee ISX23
Mr. Coffee 072179228578 12 Cup Coffee Maker Logo
2,144 people viewed this question
Top Mr. Coffee Coffee Makers & Espresso Machines Experts
Pierre Laplante
Mat Kramer
Mat Kramer
Level 1 Expert
Are you a Mr. Coffee Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
