Sony Ericsson K750i Cellular Phone Logo
Posted on Nov 13, 2007
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I cant take photos
When I open lens cover it will shows "open the lens cover" therefore i will not take any phots please solve the problem
Anonymous
Level 2:
  • Expert 55 Answers
  • Posted on Nov 18, 2007
Anonymous
Expert
Level 2:
Answers
55
Questions
0
Helped
34908
Points
116
Ok.under the lens cover there is a small switch which may lose it's place.
to find it remove the batterry cover , remove the two screws on the body of lens cover,then remove the rear cover (plastic and metal-one body) and you''ll find the tiny switch.Put it in a right place to work when lens cover open.
My Sony DSC T7 camera lens problem, When I slide the cover of lens, its says that "Lens cover Closed". so I am unable to take picture. Please help me. Thanks Anil
Mr anil there seems to be a problem with the sensor linked to the lens guard. Try to move the lens cover a few times and try to open the cover as much as possible just to initiate the sensor. If this does not solve the problem then you have to show it to a mechanic.
Regards.
tip
Solution for nikon "lens Cover Error"
Nikon Coolpix S5/S6 “LENS COVER ERROR”
In this document I have given a solution to fix the problem most of the Nikon coolpix S5/S6 cameras face. At power –on it give an error “Lens Cover Error”
Before opening the camera I would suggest you to take a snap of each and every step. Because it will helpful while you are fixing the screws back. There are many screws which has to be opened. So better take a photo of each and every step.
IMP NOTE: Remove the battery before opening the camera. Use some antistatic strip to prevent the components from getting damaged Or Keep your feet touched to the floor such that your body remains grounded.
Follow the below steps in the given order:
Step 1> Remove the screws at the bottom of camera
Step 2>Remove the side screws
Step 3> Remove the side screws as given below .
Step 4>Lift the cover and remove the cables which connects the switches to the camera. These cables are fitted in a small connector. There is a tiny lock (present for few connectors)  on the connector, which on pulling it across its hinges, will open and the cable comes out easily. You need not pull it forcefully.
Step 5> Remove the screw as shown below
Step 6> Lift the screen as shown below.
Step 7> Remove the cables and screws as shown below.
Step 8> Lift the screen panel as given below.
Step 9>
Remove cables as shown below.
Step 10>
Remove the cables as given below.
Step 11> Remove cables.
Step 12> Remove cables
Step 13> Remove the 4 wires using a soldering iron.
Step 14>
Step 15> Removing at this stage is a bit difficult. You will have to open it cleverly. Lift it from the side as shown below.
Step 16>
Step 17>Below figure shows the lens cover and the stepper motor which controls the lens civer.
Step 18> To remove the stepper motor remove the screws as given below.
Step 19> Below figure shows the stepper motor used for lens cover
Step 20> Below figure shows the stepper motor which is used to control the lens cover. There is a small white switch on this motor. This Switch is used by the camera to detect whether the camera lens cover has is open or closed. When we switch on the camera the lens cover (which is shown in step 17) opens and in turn it presses the white switch show below. If the lens cover is unable to press this switch, then the error “Lens cover Error” flashes on the camera.
I would suggest 3 different ways to solve this problem.
1>     Fix some glue on the white switch shown in the below figure, such that it remains pressed forever. Because of this, camera will never give the error message. Remove the lens cover (which is shown in step 17) forever. You don’t  need it anymore. Now fix the below stepper motor back in the camera and follow the steps in the reverse order to fix the camera components.
2>     Buy a new stepper motor from the market. Its quite cheap. Fix it back in the camera. Here you need not remove the lens cover. Follow the steps in the reverse order to fix the camera.
3>     In this method you can open the stepper motor to fix the problem. Now follow the steps given below.
Step 21>
Remove the screws as shown below.
Step 22> Remove the gears one-by-one. See the placements because you have place them again in the right order.
Step 23>
Step 24> The gear shown below is the culprit. Remove it. There is a tension spring present inside this gear. Do remember the position of this gear before removing this gear. Its placement is very important.
Step 25> The spring is shown below.
Step 26> Now the switch shown in step 20 does not get pressed because of reduced tension of the spring. Increase the tension of this spring by pulling it in opposite direction. Place the spring back in the gear and follow the steps in the reverse order to solve the problem. Now because of increased tension of the spring, the lens cover will be able to Press the switch shown in fig 20.
Happy debugging
Mukesh
I can't take photos with my phone. Once I click the camera button, the area where you see what you're taking a picture of is black. How do I solve this problem?
Some camera types need us to open lens cover manually before taking a picture, N70 foe example,
so check your phone's lens cover before capture something.
Or that's because there are less light when you take the picture, so turn on your flash light.
Hope this help and RATE please !
Jan 18, 2011 • Cameras
Kodak EasyShare V1003 Digital-Turns off and Lence projected
its the hanging of ur cam's software..it can b solved by the technicians itself..so don dave ur hand in solving it..it may b due virus from ur memeory card..so rush to the service center..don get the product spoiled more..it wont cost u much for repiaring also..
ne thing els do tell me..n plz plz do rate me..
cya
Phone not taking photos
do a master reset, menu/setting/scroll down to master reset and reset all. if that does not work then you may have to flash the firmware on the phone this can be done by taking the phone to a mobile service center or going online to www.topsony.com
Spot on finished photo
More deratail please how do you see the 'spot' on the screen or on the print or both, What was the subject matter? Any muck on the lens?
Lens Error
Firmware doesn't solve lens errors. that can only be solved by sending into repairs. Give them a call at 800-706-2534 and then keep choosing option 1.
2answers
Lens cover is stuck
I did the same repair...however, I found that those little wheels are completely optional. All they do is keep the lens cover from prying away from the camera, but if you're careful, the lens cover will work without them.
Top Sony Ericsson Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
ZJ Limited
ZJ Limited
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
